Bergepanzer Samba Member
Posted: Fri Feb 11, 2011 12:38 pm Post subject: |
| bubba wrote: |
| Had to be something installed later in it's life. They used round pipe til early 56. |
Hi,
I´m sure that on my 53 remains and on the wheelerdealer panel it´s original.
The 53 sat on its place since 1962. I doubt that in these 9 years of active service someone put in just a later hanger assembly (which is quite a big effort!) and then went back to lever shocks etc.
Everything looks factory.
I suppose that this was some kind of option or Volkswagen just experimented with different parts already at that time.
Nothing went so straight in production that 60 years after we can give a definite statement without thorough research.
Just remember: 1953; last year of Korea war; lack of raw materials all over the world; rising material prices ... so keep in mind that any suggestion for cheaper production with less energy and less waste was welcome also in Wolfsburg.
Compared with the tube version the pressed cradle is more effective regarding costs and energy. Just put in flat steel into the die and press. Neatly shaped parts fall out and can be assembled. Tubes are more expensive and have to be bent. Also there are more welding seams to be set as we all know when we look at the round cutouts in the rear chassis rail area above the rear axle. The pressed version was just resistance spot welded to the inner frame liner!
Maybe we´ll never know but I just don´t want experts to point at some BDs later with the devastating sentence: "That´s not original"
The assembly on the 54 from the djfordmanjack´s is a later conversion as the ends of the torsion tube don´t show threads for lever shocks. |
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1890 Location: Clearwater Fl.
Posted: Thu Feb 10, 2011 4:33 pm Post subject: |
Was gonna mention this but didn't have pics or exact vin #....
my main man bruce has a early single cab like Jan or feb of 56...it has a u channel for cradle and I discovered they had an option for heavy capacity or something early and that appeared to be the upgrade... _________________ www.blastserv.com
wanted:
Nothing! |
bubba Samba Member
Posted: Thu Feb 10, 2011 9:33 am Post subject: |
Had to be something installed later in it's life. They used round pipe til early 56. _________________ ***WANTED***
SO-23 Cargo net hooks...
for sale
curtain Bungee cords for SO23, 22, 33 ,34 ,35
http://www.thesamba.com/vw/classifieds/detail.php?id=1587591 |
BryanM Samba Member
Joined: June 14, 2002 Posts: 4212 Location: Concord/Charlotte NC
Posted: Wed Feb 09, 2011 12:47 pm Post subject: |
I seriously doubt VW used a post BD style hanger for part of a model year, went back to a tube then went back to the post BD style, although i guess anyting is possible.
both of the above pics show a late style hanger with BD redux boxes, narrow torsion, and the Swiss bus has late hanger and late redux boxes, likely that someone hacked in an entire late rear torsion _________________ -Bryan
Motorwagen LLC
Concord NC |
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2383 Location: Graz, Austria, Europe
Posted: Tue Feb 08, 2011 8:11 am Post subject: |
Here are the pics. 1953 BDs with pressed steel cradle ... no tubes ...
This is the gearbox cradle from 20 - 048xxx:
And this from the Wheelerdealer panel 20 - 046xxx.
Are there other early 53 models with the pressed steel gearbox cradle around???
Posted: Mon Jan 31, 2011 4:59 am Post subject: |
My January 1953 wreck find from the last weekend features a pressed steel profile cradle; similar to post 56 models.
Definitely no hand made accident repair conversion and straight spot welded from the factory.
So no cutouts for the cradle tube in the vertical sides of the main chassis rails above the rear axle.
And no telescope shocks´ mount; so definitely factory made (as telescope shocks were available from March 55).
I think the Wheelerdealer panel has the same pressed cradle (once received some pics from F. Ehrhardt).
Why did they experiment with different versions? |
Tonny_Larsen Samba Member
Posted: Sun Jan 30, 2011 4:04 am Post subject: |
| BryanM wrote: |
| Is it just me or does the bottom of the cradle look to be flatter on early than late |
I think you are right, and as I can find, the change took place between 20-033490 and 20-036112
http://www.barndoor.dk/detaljer25.html
-Tonny |
streetwagens Samba Member
Posted: Sun Jan 30, 2011 3:08 am Post subject: |
The flat bottomed cradle was another change until 20-04066. _________________ To catch a fish, you must first think like a fish.... |
BryanM Samba Member
Posted: Sat Jan 29, 2011 6:56 pm Post subject: |
Is it just me or does the bottom of the cradle look to be flatter on early than late _________________ -Bryan
Motorwagen LLC
Concord NC |
doveblue3 Samba Member
Posted: Sat Jan 29, 2011 5:36 pm Post subject: |
| Tonny_Larsen wrote: |
The change took place between 20-086697 and 20-088422
-Tonny |
20-087824 has late. |
Posted: Sat Jan 29, 2011 2:05 pm Post subject: |
-Tonny |
Posted: Sat Jan 29, 2011 11:27 am Post subject: |
Yep, My Jan '54 sc has too.  _________________ To catch a fish, you must first think like a fish.... |
bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Fri Jan 28, 2011 3:55 pm Post subject: |
My Feb 54 has the early rear frame horns... _________________ 1954 Barndoor
1955 Oval |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Thu Jan 27, 2011 6:49 pm Post subject: |
god,thats cool stuff,another thing i didnt know about..........maybe somebody....hint hint,should do a thread showing all the differences thru 52? then maybe another for the 53-55 changes? it seems theres some updating of info about due _________________ Have a great day! |
Lowdown Dirty Rat Samba Member
Joined: June 25, 2005 Posts: 892 Location: Cornwall, UK
Posted: Thu Jan 27, 2011 4:41 pm Post subject: |
Not the best but they explain what I mean
Where the horns meet the torsion tube |
Posted: Thu Jan 27, 2011 4:31 pm Post subject: Cradle horn differences |
There has been alot of talk about pre53 changes lately. Was thinking today about the mounting of the rear frame horns. On my 51 and 52 they are welded to the torsion tube and supported with a small vertical piece of metal above and below.
On later barndoors arnt they welded to the torsion tube and covered in all round. Hard to explain, I'll look for pics. |
