Temperature light and stalling...
morymob
morymob is offline
PostPosted: Tue Feb 08, 2011 7:25 am    Post subject: Reply with quote
New tank of gas??? may be a bit of water passing thru, add a bottle of gas antifreeze and water will be used up. Old blinky on mine has a mind of it's own, temp is ok so i don't worry about ti.
ddye
ddye is offline
PostPosted: Mon Feb 07, 2011 7:52 pm    Post subject: Temperature light and stalling... Reply with quote
I couldn't think of a better title so here is the deal, not sure ifnthe issues are related. On the way home from work the temperature light started flashing. This is nothing new as this has happened since I bought it. However tonight the van started sputtering and stalling. I gave it a moment and it started running fine again. Gave it a few more moments and it sputtered. Then it was fine. The entire time the tempurature lit was flashing but the gauge itself never seemed to get above e flashing light. What I mean by this is that the arrow on the temperature gauge would go to just above where the light is and stop. This is pretty normal and even when the light is not flashing this is where it stays.
Thoughts?
