What is this part?
danielsan
danielsan is offline
PostPosted: Sun Mar 13, 2011 11:00 am    Post subject: Reply with quote
Oh, and, if you restore the system the bentley has the adjustment procedure.
danielsan
PostPosted: Sun Mar 13, 2011 10:59 am    Post subject: Reply with quote
70 140 is right that it is worthless without the corresponding part that mounts onto the front of the carb -- and 9 out of 10 don't work.
If you have both parts and a 34 pict 3 it is worth using -- it helps to get rid of some of the 34 pict's flaws, especially in stop and start traffic. Even if you have a good SVDA the 34 pict isn't great off of idle. The throttle positioner / Altitude adjuster keeps the idle high for a few moments after you stop the car so you can get going quickly without stomping on the gas.
Results in smoother starts from stop signs and better performance in bumper to bumper traffic. The dash pot does the same thing.
70 140
70 140 is offline
PostPosted: Sat Mar 12, 2011 8:45 pm    Post subject: Reply with quote
Altitude adjuster. It was part of the emissions system. There is a flathead screw on the one end of it. You adjusted it with that...
Unless you are running the entire set-up with the idle controller, it is pointless. I find that the mount its attached to is a good spot to mount the rear defrost relay.
ovghiaguy
ovghiaguy is offline
PostPosted: Sat Mar 12, 2011 7:58 pm    Post subject: Reply with quote
cwatts wrote:
OK thanks mate - any idea how it works?
no idea how it works. I believe there is a vacuum pot that mounts to back of carb that is part of it. vacuum acts on diaphram which moves a lever connected to accelerator lever. I took it off mine years ago. Maybe some of the more knowledgeable will chime in. go to my pics, there is a picture of it.https://www.thesamba.com/vw/gallery/pix/784450.jpg
cwatts
cwatts is offline
PostPosted: Sat Mar 12, 2011 7:35 pm    Post subject: Reply with quote
ovghiaguy
PostPosted: Sat Mar 12, 2011 7:05 pm    Post subject: what is this part. Reply with quote
one tube goes to intake manifold left side, othe tube goes to carb. not sure which port. I believe it is an altitude compensator but don't quote me. Don't think too many use it. (people )
cwatts
cwatts is offline
PostPosted: Sat Mar 12, 2011 6:24 pm    Post subject: What is this part? Reply with quote
Hi
I have a 1972 KG convertible - I'm stumped as to what this part is for... not connected to anything at the moment. In the engine bay, connected to the rear wall to the left of the left hand side hinge.. trying to attach photo - the cable is not associated with it (just runs underneath). Any thoughts?
