No reverse lights
bread geek
bread geek is offline
PostPosted: Tue Apr 05, 2011 12:17 pm    Post subject: Reverse lights Reply with quote
I took an extra washer off the switch and it works fine. It must
Not have been making contact.
ALIKA T3
ALIKA T3 is offline
PostPosted: Mon Apr 04, 2011 9:55 pm    Post subject: Reply with quote
For the switch:you can repair the switch,there are to tiny little points inside that get corroded.You cut with a dremel to open the seam,sand the contacts and then close it back together with jb weld or equivalent
http://stanso.free.free.fr/dostek/0013.htm it's in french,but pics are good enough....
Racerrojo
Racerrojo is offline
PostPosted: Sun Apr 03, 2011 8:36 pm    Post subject: Reply with quote
Unplug the wires from the switch, plug them to each other. The lights should go on.
I had a problem with the connectors on mine, which I found after trying two switches.
Tight is tight... too tight is expensive!!!!
Too many vans and mostly all projects Smile
strawhouse
strawhouse is offline
PostPosted: Sun Apr 03, 2011 5:06 pm    Post subject: Reply with quote
Take apart your tailights and clean up the bulb holders
Pacifist with a gun
bread geek
PostPosted: Sun Apr 03, 2011 4:45 pm    Post subject: reverse Reply with quote
i will try that in the morning. Thanks
bread geek
Steelhead
Steelhead is offline
PostPosted: Sun Apr 03, 2011 4:28 pm    Post subject: Reply with quote
about to tackle this today as well. Mine works but only in certain position. mechanic told me to remove the washer on the switch, which puts it in closer contact.
'77 Bay Window / '89 Caratsburg (aka. the Stormtrooper)
vwlovr
vwlovr is offline
PostPosted: Sun Apr 03, 2011 4:12 pm    Post subject: Reply with quote
i would start by putting a volt meter or test light on the switch terminals themselves while someone else puts it in reverse. if that fails do the same test with an ohmmeter to test continuity. if you have continuity when in reverse, but no voltage then the switch is good, but power to the switch is faulted somewhere.
bread geek
PostPosted: Sun Apr 03, 2011 3:16 pm    Post subject: No reverse lights Reply with quote
I have a manual tranny and I changed the reverse switch on the tranny
Still mo luck. Wires look good at conections. Fuse is good Any ideas
