Rear shock extender's also wishbone spacers fitting. (video)
j_dirge
j_dirge is offline
PostPosted: Wed Jun 15, 2011 6:35 am    Post subject: Reply with quote
syncrodoka wrote:
j_dirge wrote:
Wouldn't a longer travel shock fix the "problem" better?
yes. The problem is finding one that fits the size requirements with the correct valving. The burley adapter linked above helps in that a longer travel shock that is known to work can be fitted.
Interesting.
Burley used his shock bracket adapter on the 16" arms he built for me.. (A cut down version) so I have one added length option...
Shock travel has not been an issue for me at ~18" fender lip to hub center.
and my current shocks work.
Nice to know the options.
So... What is the ride height zone where an extender/adapter is needed?
r39o,
What is your ride height that you want/need adapters?
Jed,
Thanks for the post.. Love your videos. Great stuff.
-89 GL Westy, SVX.. finally.
-57 pan f/g buggy with a 67 pancake Type 3 "S"
"Jimi Hendrix owned one. Richard Nixon did not"
-Grand Tour, Season 1, episodes 4 and 5
danfromsyr wrote:
those are straight line runs with light weight race cars for only 1/4mile at a time..
not pushing a loaded brick up a mountain pass with a family of 4+ inside expecting to have an event free vacation..
syncrodoka
syncrodoka is offline
PostPosted: Tue Jun 14, 2011 7:27 pm    Post subject: Reply with quote
1621
1621 is offline
PostPosted: Tue Jun 14, 2011 7:25 pm    Post subject: Reply with quote
Jed, another great installment of camper-van culture. I really enjoy the short and informative vids, please keep them coming.
For those needing a longer shock (I wouldn't recommend it if it's not necessary as there's no real benefit) I took this simple design from one of Eric D's old posts when my Konis proved too short for the GW springs. In this case, I didn't want to change an already awesome damper. Very simple if you can source a set of old shocks and have a friend who can bend and weld. Did a set for the fronts too.
'85 Westy
j_dirge
j_dirge is offline
PostPosted: Tue Jun 14, 2011 6:50 pm    Post subject: Reply with quote
skivan
skivan is offline
PostPosted: Tue Jun 14, 2011 5:37 pm    Post subject: Reply with quote
Thanks as always Jed. Now back to the intent of this thread -- the shock knock...
when i go over a speed bump/hump a little too quick the down stroke is quite harsh and i'm assuming this is what you're calling shock knock. this is the shock topping out or fully extended? seems kind of obvious now that i'm writing. this happens in the front and rear with GW 2" springs/OME shocks.
so upper ball joint spacers and rear extenders would help this issue? thanks for any comments.
'87 subaru westy syncro
'04 TDI passat wagon
Jedi
Jedi is offline
PostPosted: Tue Jun 14, 2011 4:15 pm    Post subject: Reply with quote
http://burleysmotorsports.com/index.php?main_page=product_info&cPath=16&products_id=38
1961 Westfalia SO23 Mango Green/Seagull grey
1961 Westfalia SO34 T/BW
1961 Westfalia SO34 SWR
1964 Westfalia SO33 pearl white
1965 Westfalia SO42 Velvet green
1986 Syncro Wolfram grey with black int GL
1986 Syncro Doka
1987 Syncro Sevana beige Adventurewagen
1987 syncro Sevana beige GL
1973 Pumpkin orange Thing
2 1963 Rag top bug's
1965 Manx
1970 Single cab
1971 combi
1990 Vanagon GL
2007 Audi A4 3.2L quattro
syncrodoka
PostPosted: Tue Jun 14, 2011 4:02 pm    Post subject: Reply with quote
BushChicken wrote:
Looks like you could mount some of these upside down with a little grinding maybe?
Those are designed to work with a longer shock giving more articulation. That is more important for actual use than the extenders- which are a way to bypass getting longer shocks and still lift it.
BushChicken
BushChicken is offline
PostPosted: Tue Jun 14, 2011 8:44 am    Post subject: Reply with quote
r39o wrote:
I want some of those rear extenders NOW!
Who has those here?
Gotta have, I think.
They rear extenders do NOT seem to be on the website.
What am I doing wrong?
snoop
snoop is offline
PostPosted: Tue Jun 14, 2011 6:37 am    Post subject: Reply with quote
87 Westy Camper
JED THE SPREAD
JED THE SPREAD is offline
PostPosted: Mon Jun 13, 2011 10:59 pm    Post subject: Reply with quote
The extenders from www.futbus.com are for raised vans, it relocates your rear shock mounting point so you can still use standard shocks. I know he will ship to the US/Canada etc so if you send him an email I guess he should get you a price.
Futbus is a small family run outfit who have spent a great deal of time developing upgrades for bus's over the years and showing what they do for someone to copy directly wasnt my intension. He has already had some cases of people ripping off his ideas in the UK but it ended up doing him a favour in the end because some of the stuff that was copied was rubbish Laughing
Glad you all like the video, it keeps us going at it Wink
jed
Visit CAMPERVANCULTURE.COM real camping and video uploads
Subscribe to Campervan Culture by Email
Follow us on Facebook, Campervanculture.com
syncrodoka
PostPosted: Mon Jun 13, 2011 3:54 pm    Post subject: Reply with quote
Why? Do you have a syncro with a tall lift?
BenT Syncro
BenT Syncro is offline
PostPosted: Mon Jun 13, 2011 2:01 pm    Post subject: Reply with quote
Another fantastic piece, Jed.
Wondering about that rear shock extension. It doesn't to add to the wheel travel at all, does it? More like a 'shock mount relocator' than an extension.
Cheers,
BenT
Rhinoculips
Rhinoculips is offline
PostPosted: Mon Jun 13, 2011 11:07 am    Post subject: Reply with quote
Nice video. Well done, idiot proof and a great soundtrack. Thanks for sharing.
“May your trails be crooked, winding, lonesome, dangerous, leading to the most amazing view. May your mountains rise into and above the clouds.” - Edward Abbey
Click to view image
JED THE SPREAD
PostPosted: Mon Jun 13, 2011 10:40 am    Post subject: Rear shock extender's also wishbone spacers fitting. (video) Reply with quote
I thought I would share with you a couple of jobs I did on my Westy a little while back. The first job was due to advice given on here when I raised my front suspension and I now have wishbone spacers fitted and doing well. The second thing was to fit some rear shock extenders to help the van not to top out if it was ever empty. This is a new product available in the UK...
Remember as always we are not pro's and we are just having ago on our own vans because we are average Joe's, and if you know a better way to do anything feel free to stick to what you know Wink
Here is a video of what went on, http://campervanculture.com/2011/06/fitting-rear-s...ia-syncro/
jed
