Carb fuel inlet aint in. PICS
myfresh70
myfresh70 is offline
PostPosted: Wed Aug 10, 2011 6:26 pm    Post subject: Reply with quote
HUGE help. thank you guys.
ill let you know how it works.
Lionhart94010
Lionhart94010 is offline
PostPosted: Wed Aug 10, 2011 4:38 pm    Post subject: Reply with quote
Thanks for the spec BD-
FYI, Found a samba post with links where to buy parts :0)
http://www.thesamba.com/vw/forum/viewtopic.php?t=420661
1/4 x 1/16 Hose Barb X Male Adapter ( $4.35)
http://www.fastfittings.com/product/32301
1/16"-27 NPT National Pipe Taper High Speed Steel Pipe Tap ($5.90)
http://www.amazon.com/National-Pipe-Taper-Speed-Steel/dp/B000U7LSPO
Current VWs 71 T2 Westy SO-72/6(Miami), 71 Crew Cab, 2015 GSW TDI
Other owned VW’s 59, 68 1500s, 69 & 71 Bug’s; 72 & 73 S-Bug’s; 67 Westy, 67 Deluxe, Other 71 DC, 72 KG GT that now lives in Australia, 12 JSW TDI, 2015 GSW TDI, 2023 Tiguan
VW technical information sights
thesamba - www.ratwell.com - www.shoptalkforums.com/ - www.vw-resource.com - http://www.type2.com/
http://bobhooversblog.blogspot.com/ - www.aircooled.net/gnrlsite/resource/articles.htm
busdaddy
busdaddy is offline
PostPosted: Wed Aug 10, 2011 4:02 pm    Post subject: Reply with quote
Yep, 1/16" NPT IIRC, hard to find but available online, there's a link in one of the many fuel line threads.
Now go buy yourself a lottery ticket Shocked
Слава Україні!
Lionhart94010
PostPosted: Wed Aug 10, 2011 4:00 pm    Post subject: Reply with quote
You’re lucky you found it when you did; the thing to do is thread in a brass pipe fitting as they do on Formula V prepped Solex carbs…
myfresh70
PostPosted: Wed Aug 10, 2011 3:46 pm    Post subject: Carb fuel inlet aint in. PICS Reply with quote
searched and found nothing.
so, i was driving the other day blah blah blah, got home and lifted the engine door to let her cool off, then i smelled STRONG gasoline and thought, oh crap. so i looked at my fuel lines and the inlet to the carb was soaked. so i played with it and it just slid right out!
so i plugged the line and am trying to figure out the best way to fix the carb.
should i get some kind of gas resitsant sealant? and switch ends and press in the good end? gimme yo ideas! thanks.
