Cygnus Samba Member
Posted: Sat Aug 13, 2011 6:45 am Post subject: |
Ah Thanks, didn't mean to derail the thread. I will go ahead and get a 3 wire.. My 85 runs pretty hot - I have looked at those oil coolers but it seems a bit too fiddly. I am going to start by going after my radiator - I suspect it is getting clogged.
-B |
Ahwahnee Samba Member
Joined: June 05, 2010 Posts: 10318 Location: Mt Lemmon, AZ
Posted: Fri Aug 12, 2011 3:45 pm Post subject: |
| bserret wrote: |
| Captain Pike wrote: |
| It will not fit with a 1.9 exhaust.Done. |
Hmmm, being that its a 2.1 engine, how can I be sure that I have a 1.9 exhaust? Are they interchangeable? |
I think the Cap'n was referring to the 2.1 oil/water heat exchange.
You should have no problem putting a 3-wire O2 sensor on a 1.9 or 2.1 or whatever if that is what you want. Desirability may depend in part on where you live and how you drive. |
r39o Samba Polizei
Posted: Fri Aug 12, 2011 10:14 am Post subject: |
| Wildthings wrote: |
| 300,000 miles without needing it! |
I know of another one with over 300K miles on it too. NEVER been split apart or heads off.
You got to figure the math says there must be a few that beat the curve.
It DOES happen. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
klucz Samba Member
Joined: February 14, 2006 Posts: 1062 Location: Chicago, IL
Posted: Fri Aug 12, 2011 8:18 am Post subject: Re: Retrofitting an 2.1L Oil Cooler into a 1.9L Digijet |
| windnsea wrote: |
| Mileage is now ... ~26 on backroads @ 50 mph in Central California! |
Really? _________________ 84 Westy 4spd sold |
Cygnus Samba Member
Posted: Fri Aug 12, 2011 7:17 am Post subject: |
Thx,
-B |
Posted: Thu Aug 11, 2011 10:45 pm Post subject: |
| 300,000 miles without needing it! Why would you want to add anything that isn't necessary, adds complexity, and has a failure mode? If you are worried about the oil being negatively affected by heat, run synthetic instead of dino. |
Captain Pike Samba Member
Joined: December 30, 2003 Posts: 3466 Location: Talos IV, Piedmont Arizona
Posted: Thu Aug 11, 2011 8:29 pm Post subject: |
Cygnus Samba Member
Posted: Thu Aug 11, 2011 2:41 pm Post subject: |
I would also be really interested in the details of adding a 3 line o2 sensor to a digjet with a 2.1 because my single wire sensor is out I believe and I have that same setup.
Thanks,
-Brian E. |
Spinal Tap Samba Member
Joined: August 01, 2008 Posts: 413 Location: Chicago IL
Posted: Thu Aug 11, 2011 12:25 pm Post subject: |
If you want to add an oil cooler, talk to Tencentlife. He has a nice kit for adding cooler to both the 1.9l and 2.1l. _________________ '85 Westy
'74 MG-B
| RCB wrote: |
| Its called tact...and tact is the ability to tell someone to go to hell in such a manner that they anticipate the trip. |
r39o Samba Polizei
Posted: Thu Aug 11, 2011 10:24 am Post subject: |
It is NOT an oil cooler. It is a heat exchanger. Or "stabilizer." It will want to make the water and oil the same temperature. Not much gain there when you talk about cooling.
Mount an external air oil cooler. There are posts on this topic. Might start in the FAQ.
FYI: *IF* current engine is running so well, leave it alone. Do as I did and just build up another newer van. I did and love it. The Suby really makes the van fit in with traffic and even more a joy to drive. My $0.02. _________________ "Use the SEARCH, Luke" But first visit the Vanagon FAQ!
bquigs Samba Member
Joined: March 01, 2008 Posts: 116 Location: Kittery, ME
Posted: Thu Aug 11, 2011 8:41 am Post subject: |
If I understand you right you would use the water/oil cooler but run air though it instead of water? I don think this would be efficient enough to do anything at all even if you were to get an air flow through there which is unlikely. Water absorbs much more heat than air so the water/oil cooler is small and doesn't have much surface area for heat transfer. What you need is a radiator in the D piller that you move the oil through. _________________ -----------------
87 Syncro Zetec |
Wellington Samba Member
Joined: September 21, 2004 Posts: 2024 Location: Montreal
Posted: Thu Aug 11, 2011 2:55 am Post subject: |
More details on the 3 wire oxy sensor please.
Not sure of your explanation of retrofit 2.1 system, but I'd rcommend 10cents cooler system or your own of the same variation. Chris has put together a kit to same you all the time and trials, |
windnsea Samba Member
Joined: May 07, 2008 Posts: 424 Location: Pasadena, CA
Posted: Thu Aug 11, 2011 1:34 am Post subject: Retrofitting an 2.1L Oil Cooler into a 1.9L Digijet |
Hey group!
I finally got my 2.2L wasserboxer mit digijet fuel injection running properly after putting in a 3-wire O2 sensor!! Mileage is now 19+ in town, ~22 on the open road, and ~26 on backroads @ 50 mph in Central California!
Though I've never had any overheating at all in almost 28+ years as using DAS BOX as my primary driver, and have regularly changed the oil and everything else, I've got a question, which is as follows:
I've got the parts available to retrofit a 2.1L digifant oil cooler to my 2.2L digijet engine. If I was to go ahead I would not do a digifant retrofit to make it a water to oil cooler, but rather I'd route a hose up into the left rear D-pillar to catch it's air flow to be used as the cooling medium rather than doing a rather significant restructuring of the water cooling hoses in the back left side of the engine. I'd make a pressure routing of air with all possible moisture draining without entering the oil cooling duct.
Any comments?? I'd appreciate any feedback that my fellow Sambanistas could throw at this idea!!
Windnsea
BTW, DAS BOX is now approaching 300,000 miles of enjoyed driving, and is starting to whisper as I sleep ( WRX STI, WRX STI,WRX STI,WRX STI)!
Is this like those Canadian Vanagons chanting "Wheetabix, Wheetabix, Wheetabix" ?
I think that those Canuck Vans need more fiber under their wheels!!
Windnsea |
