Wiring Mess
Mr Whippy
Mr Whippy is offline
PostPosted: Sun Sep 11, 2011 2:41 pm    Post subject: Reply with quote
If you look at the drop down headings at the top of the screen, the technical one has heaps of wiring diagrams, including the one for your car.
The bugs wiring is very simple. If you work on one system at a time it is quite easy.
First to tackle is the starting and charging system, then the lights, then the indicators, then the wipers and remaining switches.
If you can afford it though I'd recommend a new wiring loom, especially if you are not use to doing wiring, in the long run it will be more reliable
RebaMarie
RebaMarie is offline
PostPosted: Sun Sep 11, 2011 2:33 pm    Post subject: Wiring Mess Reply with quote
Hey guys, I've got a 69 beetle that the former owner put a baja kit on and in the process he messed with the wiring. I'm not sure just where the wiring harness that I ordered from Jbugs goes because the old wiring harness was ripped out. (Part of it was cut and left in the pathway in the rear of the body and he ran his wiring through the heater channel Confused ) I've got about half of it where I think it should be but the other half I'm not sure. I don't know what to do. Has anyone ever used the Bug Me vol. 9 video? Does anyone know how much it might cost to have it intalled? Any help would be greatly appreciated!
1969 Baja
