Main bearing orientation question
motofly196
motofly196 is offline
PostPosted: Wed Feb 27, 2019 4:26 pm    Post subject: Re: Main bearing orientation question Reply with quote
I know I'm reviving an old thread, but this info was valuable. Thank you Jack's!
Jacks
Jacks is offline
PostPosted: Sun Jul 19, 2015 5:13 pm    Post subject: Reply with quote
According to the late 356 guru Harry Pellow, the oil hole that is furthest from the dowel pin should be positioned toward the camshaft, or the bottom of the cases. I agree with him.
Jack Staggs
Actual name
Matthew Tolbert
Matthew Tolbert is offline
PostPosted: Sun Jul 19, 2015 4:43 pm    Post subject: Reply with quote
Reviving an old thread here. I have a similar question but with the #3 bearing behind the crank gears. The dowel pin is centered in the saddle and the bearing will work either way but is one direction preferred over the other? The only difference is the location of the oil holes in the bearing move a few degrees.
Matthew Tolbert
1958 ragtop
1961 doublecab
1965 Notchback S
modok
modok is offline
PostPosted: Fri Dec 02, 2011 12:44 am    Post subject: Reply with quote
outside
ozarkbaha
ozarkbaha is offline
PostPosted: Thu Dec 01, 2011 10:42 pm    Post subject: Reply with quote
your dowel pin holes go toward the flywheel look at your case they are off set toward the back hope that help not sure what you are saying
Snort
Snort is offline
PostPosted: Wed Nov 09, 2011 7:35 pm    Post subject: Reply with quote
Here is a photo from the gallery. Hope it helps.
Braukuche
Braukuche is offline
PostPosted: Wed Nov 09, 2011 7:44 am    Post subject: Main bearing orientation question Reply with quote
Real quick, I am putting my 36hp together and the directions are unclear on orientation of the main bearing right behind the pulley, does the groove in the bearing go on the inside or the outside?
Go Reds! Smash state!
Retirement is here!
1960 double cab
1960 Baja Bug
1963 stretched double cab
1962 Golde sunroof Ghia
1963 356 B coupe
1963 Notchback
1967 21 window less rusty now
1989 Westfalia
