SDBug Samba Member
Joined: January 24, 2004 Posts: 83 Location: Sioux Falls, SD
Posted: Wed Nov 30, 2011 2:32 pm Post subject: |
That link goes over exactly what I am going through. I guess I needed to search for turn signal and not blinker! Thanks for the input and I'll see how it works tonight! _________________ Former owner 68 beetle
Current 67 beetle |
VOLKSWAGNUT Fastest VW Belt Changer
Joined: October 14, 2007 Posts: 11158 Location: Flippin' a Belt........ .... Off-n-On ... NC USA
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16803 Location: State College, PA
Posted: Wed Nov 30, 2011 2:05 pm Post subject: |
Yeah - once you get the meter - do this first - see what wires make connections in the various positions and jot it down
For example - dimmer switch pushed connects black and black/white
Left turn signal connects brown and orage
right turn signal connect pink and purple
These are not correct colors - just an idea of what info to have when you post again.
I had the same issue and figured it out myself, but its been a while. _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
Posted: Wed Nov 30, 2011 1:51 pm Post subject: |
SDBug wrote: |
Here are the wires I am wondering about along with my best guess as to where they are supposed to go.
1. Short brown (supposed to go to the horn but its nowhere near long enough?)
2. Brown White + Brown combo/pigtail wire (BR/W to dimmer relay (J2), then brown to wiper switch (E)?) Funny thing about this, when I connect the brown/white to the dimmer relay and the brown to the wiper switch, every time I turn the lights on and off I get bright, then dim, then bright, etc.
3. Black + Blue combo (Black to 49a on the Turn signal & emergency flasher relay (J1), then blue to ??? The blue has a very small connector on it and I don't see anywhere that has a male spade that small for it to even fit?)
Thanks! |
The horn circuit is not part of the actual turn signal circuits and wiring for it.
Do you have 5 terminals (circuits) coming from the turn signal switch harness?
If so name the colors of them all.
Aftermarket switches have had an issue with wire color consistancy... we have delt with these, but you need to have an ohm meter or continuity tester.
From another post..
glutamodo wrote: |
aha, aftermarket. What color wires? I think there's been different ones in the aftermarket and I'm not really sure if there is any kind of consistancy in the wiring colors. Really though, just 5 wires, and the two for the headlight clicker should be obvious, so that's 3 wires. If you have an ohm meter it's not very difficult to figure out which is the "middle" connection and then the two that branch off for Left and Right. |
_________________ aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited |
SDBug Samba Member
Posted: Wed Nov 30, 2011 11:19 am Post subject: |
Thanks! _________________ Former owner 68 beetle
Current 67 beetle |
Posted: Wed Nov 30, 2011 11:08 am Post subject: |
AHHHH The turn signal switch.
Post ALL the wire colors... Should be 5 different circuits (wires) _________________ aka Ken {o\!/o}
SDBug Samba Member
Posted: Wed Nov 30, 2011 10:39 am Post subject: |
Ok when you say blinker...do you mean flasher? _________________ aka Ken {o\!/o}
SDBug Samba Member
Posted: Wed Nov 30, 2011 10:26 am Post subject: MAMotorworks Blinker Install |
I'm having a hard time figuring out exactly how to finish my blinker install. I got one from Mid American but can't figure out the right setup. I have gone over the wiring diagram for a 67 but that doesn't match up to what their blinker comes with. A couple emails from them don't help either as one email from them gives 2 different answers to what does what. My main question (if anyone else has ordered one from them) is what do I do with the short brown wire, the longer brown/white wire with the brown extension, and the black wire with the small blue extension (the blue extension has a tiny female spade connector and I dont have any male connector that will fit it).
Am I being dumb and just missing something or is there something I am losing in translation?
Here is their answer to my question.
brown and brown with yellow stripe are for the dimmer
black with the little blue wire is the main feed wire
green with black stripe is right turn
black wht white stripe left turn
Dimmer Switch is on the end of the turn signal lever, on the
forward (bottom) side. just a narrow clicker switch.
9-27-10/4283mark
Mark and Russell’s version 10-26-07
Car Switch
BK/wh to BK/wh to LH Turn Signal
BK/gn to GN/bk to RH Turn Signal
Bk/Wh/Gn to BK w/BL/Bk extension to Turn/Flasher Relay
BR to BR to Dimmer Relay
BR/wh to BR/yw w/BR/yw extension to Windshield Wiper Switch _________________ Former owner 68 beetle
Current 67 beetle |
