Help me identify this part please
Scubavw
Scubavw is offline
PostPosted: Sun Jan 29, 2012 4:50 pm    Post subject: Reply with quote
Looks like one that I pulled off my 65 bug.
molybdanum
molybdanum is offline
PostPosted: Sun Jan 29, 2012 3:18 pm    Post subject: Reply with quote
I would inspect the upright you pulled for a molded in part number, to match up. There are two uprights one for manual steering and one for power steering. I tried to look up the part number of both versions of left uprights, but both are nla on Vagcat.
-Dan
85 Vanagon Westfalia EJ22
00 Passat GLS Wagon
molybdanum
PostPosted: Sun Jan 29, 2012 3:04 pm    Post subject: Reply with quote
The spindle you have recieved does not belong on a vanagon. The one you took off is normal.
-Dan
00 Passat GLS Wagon
tschroeder0
tschroeder0 is offline
PostPosted: Sun Jan 29, 2012 2:44 pm    Post subject: Reply with quote
BUMP, and to add a bit more I guess the overall question is: does this look like an 85 front spindle/knuckle or not maybe some of you could take a look on your vans and see what mine matches up to
again mine is the one on the LEFT.
Thank you all again. Todd.
tschroeder0
PostPosted: Sun Jan 29, 2012 1:25 pm    Post subject: Help me identify this part please Reply with quote
OK so I had a bearing go bad and it wrecked my spindle on my 1985 weekender westy made in 2/85 (that is, it is not a late model 85)
I had a new spindle sent to me and it is not like mine it is smaller(not as "tall") and the spindle itself is less beefy, when I look around it looks as if I may have an 86-91 spindle? Mine sure looks like what all the vendors tell you to source when upgrading to the big brake kits.
I am quite certain that the spindle is stock, I have owned the van for 12 years and the previous owner I am sure never changed them. And I have always run stock 85 rotors on the front??
So I need some help so I can source the right part.
Thank you! Todd.
*My original spindle is on the Left and the one sent to me is on the Right*
