joseph928 Samba Member
Joined: September 22, 2011 Posts: 2114 Location: flagstaff az.
Posted: Mon Feb 27, 2012 3:02 pm Post subject: differential |
Sounds like to me you have one van with a limited slip differential, and one with a open differential! and one may need to be looked at. The limited slip should feel the same when driving, as a open one. _________________ 1987 syncro westy tin top sun roof , GW2.3, rear locker, decoupler, Gary Lee tire rack & winch mount, lift, south african grill, big brakes , rhein alloy ,15 BFG AT, Fiamma 10 foot awning ,140 watt rear 85 watt front solar , mppt, truckfridge, automatic fire extinguishing system, tencent oil cooler, And a RMW SS exhaust! - 1971 bug convertible 1776 engine- 2010 Subaru turbo - 1993 Toyota 4x4 truck - 1999 Harley 95 CI, big bore, Andrews cams . Also 80-84- vans. Stock 65 sunroof bug. |
crazybaja1 Samba Member
Posted: Mon Feb 27, 2012 2:04 pm Post subject: Any one help ?strange problem... |
The car is acting strange in turns and even vibrate like there is no differtial..i checked it up on the lift and saw something unusuall:when i turn one of the rear wheel to one side the other turns to the same side and not the oposite! but when i grab it and someone else turns the other it turn so it's like half lock i compered it to other vanagon of mine and it's not like that,there is no any resistance.
Ideas? someone?
Is there any option that the differtial stuck or the spiders not good?
Thanks!!
 _________________ 91' Vanagon (165h.p 2008 legacy engine)
72' Baja bug in proces
71' Squareback originall not restored
87 sinca
82 sinca
70 doka
73 bug callook
71 class 11 |
