MichaelBrenner Samba Member
Joined: July 16, 2008 Posts: 137 Location: Costa Mesa, CA
Posted: Tue Mar 06, 2012 6:53 pm Post subject: |
Thanks guys, hopefully these will survive in my 12:1 desert motor as long as I don't get greedy and try to lean it out too much this time!
Narrow envelope: 150 main/120Z air was rich, 140 main and 150Z air burnt through #3! Damn it ran nice until though..... I'm thinking 145 or 147.5 with 120Z this time around depending on what the AFX tells me. It's just money right!?! _________________ Brenner Racing
SNORE 1179 |
DarthWeber Samba Member
Joined: November 24, 2007 Posts: 7543 Location: Whittier,CA
Posted: Mon Mar 05, 2012 8:58 pm Post subject: |
Might get high but you will get a better view!
I referenced AC.Net in my first post above. FYI. YMMV. AFL/CIO RIP IRS.... _________________
Mitey62 wrote: |
Swapped the Compufire for a Bosch blue and some points I had sitting around, started 1st crank. Took her out for a drive, pulls harder, more RPM, and runs smoother. I think I'll be sticking with points from now on. |
RockCrusher wrote: |
JB weld the case halves....that'll keep the fretting to a minimum.  |
spencerfvee Samba Member
Posted: Mon Mar 05, 2012 4:53 pm Post subject: |
can i get high doing that ? spencerfvee
DarthWeber wrote: |
Spencer, go up 2 flights of stairs ^^^  |
Posted: Mon Mar 05, 2012 3:33 pm Post subject: |
Spencer, go up 2 flights of stairs ^^^  _________________
Mitey62 wrote: |
Posted: Mon Mar 05, 2012 2:15 pm Post subject: |
have you tried john at air cooled for a set ? or jake raby . or F.A.T . gene berg spencerfvee
MichaelBrenner wrote: |
There are no 85.5 forged available as far as I know, if you have a set somewhere I would gladly buy those up right now. |
gimmesomeshelter Samba Member
Joined: May 08, 2004 Posts: 1466 Location: San Carlos, CA
Posted: Mon Mar 05, 2012 1:19 pm Post subject: |
Hello-
Quote: |
Buy the best and cry once. |
X2.
Cheers,
Paul _________________ "I would rather have questions that can't be answered than answers that can't be questioned."
Richard Feynman |
Posted: Mon Mar 05, 2012 11:16 am Post subject: |
http://vwparts.aircooled.net/Mahle-Piston-Cylinder-Set-85-5mm-x-69mm-Forged-p/85.5x69fm.htm
Don't whine about the price now! Buy the best and cry once.  _________________
Mitey62 wrote: |
Posted: Mon Mar 05, 2012 9:51 am Post subject: |
There are no 85.5 forged available as far as I know, if you have a set somewhere I would gladly buy those up right now. _________________ Brenner Racing
SNORE 1179 |
Posted: Mon Mar 05, 2012 5:06 am Post subject: Re: Mahle Cast 85.5 vs. AA Cast 85.5 |
all stock pistons were made the same way . you get what you pay for .i like A&A pistons i think there stock cast pistons are the same as mahle . if you want better pistons go with a set of mahle forged pistons . from $170.00 to $200.00 a set now adays . spencerfvee...................................
I have a set of the Mahle Cast with the steel strut in the wrist pin area, that strikes me as not good since it's dissimilar metal to the piston and I would think that it would expand differently than the rest of the piston when pushed to the limit. The oil ring slot is also alarming with how large it is, I've read that these pistons will sometimes crack with this large cutout in the piston. The cylinders seem to be reasonable quality, and all the pistons/cylinders seemed to deck very consistently when I mocked up the pistons/cylinders.
Anyone here have any real experience or knowledge of whether the AA's are much different or similar in quality? The AA's are much cheaper and I'm hoping they are a decent alternative or possible better? |
Posted: Mon Mar 05, 2012 3:24 am Post subject: Mahle Cast 85.5 vs. AA Cast 85.5 |
Anyone here have any real experience or knowledge of whether the AA's are much different or similar in quality? The AA's are much cheaper and I'm hoping they are a decent alternative or possible better? _________________ Brenner Racing
SNORE 1179 |
