Clutch Cable Idea .....again.
BL3Manx
BL3Manx is offline
PostPosted: Sun Jun 10, 2012 1:04 pm    Post subject: Reply with quote
This is the best hydraulic clutch master cylinder installation I've ever seen on a VW pan, one small round hole in the tunnel, no holes in the body, easily accesible.
crashtestdumba$$
crashtestdumba$$ is offline
PostPosted: Sun Jun 10, 2012 12:47 pm    Post subject: Reply with quote
i decided to go "hydrological" Smile
gonna take out the shortened cable and let the fluid to the work. I will shoot up some pics anyone is interested.
Greg
clonebug
clonebug is offline
PostPosted: Sun Jun 10, 2012 9:05 am    Post subject: Reply with quote
A loop with 3 cable clamps is quite easy to do.
I cut mine and used 3 clamps. It has been going with zero problems for almost eight years now.
Only the young bucks are going to bend down and look under the body behind the wheel, Most of them probably wouldn't know what a clutch cable is let alone one that has been cut and shortened. Wink
richardcraineum wrote:
I'm so ignorant of efi I don't even know the difference between batch, sequential blah blah blah ..
cbeck wrote:
His user name in a previous life was dick head.
Water/Alcohol Injection
Audi TT intercooler
Upgraded to MS3Pro-Evo
EcuMaster PMU16
ECUMaster ADU5 Digital Dash
http://www.shoptalkforums.com/viewtopic.php?f=3&t=127936
BL3Manx
BL3Manx is offline
PostPosted: Sun Jun 10, 2012 8:43 am    Post subject: Reply with quote
Yes, the pedal would have to travel twice as far.
I might look at a McMaster Carr 3099T13
Lo Cash John
Lo Cash John is offline
PostPosted: Sun Jun 10, 2012 8:33 am    Post subject: Reply with quote
Correct. You double the total travel needed to do the work, but cut the force required in half. Since the stock design has more than enough stroke, this works out.
www.LoCashRacing.org
Lo' Cash Racing Team on Facebook
More brains than bucks...Believe it or not!!
My boss told me I need to work on my mutli-tasking. So now when I use the bathroom at work I surf The Samba on my iPhone.
Dale M.
Dale M. is offline
PostPosted: Sun Jun 10, 2012 8:16 am    Post subject: Reply with quote
Would not the cable wrapped around a pulley decrease the length of pull by 1/2 (something about the physics bothers me) seems you will only get half the movement needed to engage/disengage clutch...
Same concept as using snatch block with winch.... You increase pull ration in power (2x) but decrease distance moved by 1/2....
Dale
Lo Cash John
PostPosted: Sun Jun 10, 2012 7:53 am    Post subject: Reply with quote
Good call on the sideways deflection. The physics in my brain don't generate those kinds of unwanted results. Very Happy
BL3Manx
BL3Manx is offline
PostPosted: Sun Jun 10, 2012 6:35 am    Post subject: Reply with quote
I think that would cause the pulley to want to go sideways as you pressed the pedal. I think you need to keep the cable runs parallel if you want a linear action.
Thinking about it, if the cable only had a single run, I don't think a regular saddle clamp would work very well. The best thing would be to run the cable through a hole in a fitting which has a couple set screws perpendicular to the cable hole. Kinda like this
The cable could go through a hole in a steel bracket mounted on the trans and the fitting would anchor the cable on the other side of the bracket. There would only be half as much tension on the fitting/set screw, so the cable would probably last forever without breaking.
Lo Cash John
PostPosted: Sun Jun 10, 2012 6:22 am    Post subject: Reply with quote
I'd had the same thought a while back and was/am going to try it on my buggy build. My thought was to have the cable go around the pulley at a 90* angle, and have an attachment point somewhere on the passenger side. This way to adjust the clutch you just reach somewhere behind the passenger back tire and twist the wingnut. No climbing under the car necessary.
BL3Manx
BL3Manx is offline
PostPosted: Sun Jun 10, 2012 6:03 am    Post subject: Reply with quote
Its been around a while. Its had good reviews from people who use it. I still think you'd need to shorten the cable unless you anchored it someplace closer to the nose of the trans than in this picture. You could mount a cable clamp in place of the long nut on the trans in the picture.
http://www.thesamba.com/vw/forum/viewtopic.php?t=349597&highlight=clutch+cable+pulley
VolkswagenGerry
VolkswagenGerry is offline
PostPosted: Sun Jun 10, 2012 1:34 am    Post subject: Reply with quote
I am Right at the clutch cable shorting phase myself, with the cable sticking out of the bowden tube at full lenght. (I had to cut into tunnel and do clutch tube repair at pedal assembly where factory tack had failed).. and now on to the shortening... I saw a thread simmular where some one had the Pully Cha-Cha "Clutchen-unst-shortenhowzer" set up. So my wheels have been turning as to this approach OR the cut and Saddle "Clampin-das-cable" Cha-Cha. Think
I do think the Samba members product is cool.
Also thinking out-loud,
Ditto on using anybodys cable if needed.
time to forum search "shorting clutch cable" to refresh my mind and see how many un-related threads I can find to keeb me busy untill I fall asleep.
Murzi, the second link shows having an aluminum pully wheel, Wouldnt this wear fast against a steel cable?
MURZI
MURZI is offline
PostPosted: Sat Jun 09, 2012 9:05 pm    Post subject: Clutch Cable Idea .....again. Reply with quote
So..... I am looking around at ads on here and I stumble across this gem. I start thinking what if you DON'T shorten your clutch cable, wrap it around a pulley like this, or smaller if you need more feel, and attach the cable end to a bracket somewhere on the tranny. No cutting cables ANYMORE, and if you break down(VINCENT Crying or Very sad Crying or Very sad ) you can borrow ANYONE's clutch cable. NEAT IDEA HUH??? Just thinking out loud.
http://www.thesamba.com/vw/classifieds/detail.php?id=1109114
http://www.sciencelabsupplies.com/Pulley_on_Rod_Aluminum.html
62 vert
2276
Tim’s welded heads
45 Dells
A1 sidewinder
Fk44 cam
