356 turn signal flasher relays
jjjjack
jjjjack is offline
PostPosted: Fri Jul 27, 2012 4:52 am    Post subject: Reply with quote
Jacks wrote:
The 4th wire on the pre a (and some early t1) supplied an external ground for the flasher can. Later model cans did not require the additional wire. The ground wire appears to be an internal function to the can, not the signal system, as I have fitted 2 or 3 prong cans on many early cars with no loss of function to any lights or systems. It is interesting that the 'new' transistorized units (zims etc) require fitting of a ground wire. 3 prong plug sockets for the can appeared in t1 production, and were used until the end of the 356 production
So, to be sure I understand...and so we don't leave this hanging here, too, you're saying that you've had success with the non-Zim's 3 prong flasher in the Pre-A? What should be done with the 4th wire -- just leave it unattached? I'm still not clear if anyone ever got the Zim's flasher to work with the Pre-A based on the Registry thread.... Sad
TIA,
Jack Stenner
1959 Mango Westfalia SO-23
1953 Porsche 356 Coupe
IG:j.stenner
View user's profile Send private message Visit poster's website Twitter Instagram Gallery Classifieds Feedback
jjjjack
jjjjack is offline
PostPosted: Fri Jul 27, 2012 4:36 am    Post subject: Reply with quote
roy mawbey wrote:
Jack,
Please advise if its possible the procedure you used to put the 'flasher' in operation photo on the forum. Did you take a take a short camera video and upload this to the forum? Is that possible?
I liked that Very Happy
Roy
LOL, sure. It's just an animated gif. I shot two still frames, one with the light on and one off, set to cycle forever @ .9ms in Photoshop and saved as animated gif. It took maybe 10 minutes. First I uploaded it to theSamba, but it would only display the first frame (i.e., not animate). So, I uploaded it externally, linked it, and that worked as it should. Smaller and more lightweight than a video Smile
I don't think you can upload videos here...just embed YouTube, Google Video....
HTH,
Jack Stenner
IG:j.stenner
roy mawbey
roy mawbey is offline
PostPosted: Fri Jul 27, 2012 3:51 am    Post subject: Reply with quote
Jack,
Roy
Roy
RHD356A super75 106954
Jacks
Jacks is offline
PostPosted: Thu Jul 26, 2012 9:32 pm    Post subject: Reply with quote
Jack Staggs
Actual name
ensys
ensys is offline
PostPosted: Thu Jul 26, 2012 8:53 pm    Post subject: Reply with quote
Gentlemen:
I don't think the issue of socket is settled as my T-1 A did not have one. Instead, a clip held the barrel of a flasher with screw-on connectors.
I had to build wire end adapters for the later 12v can I use currently.
I'll have to check later to see if the original was 3 or 4 pole.
Keep 'em flying...
S.J.Szabo
Suboval
Suboval is offline
PostPosted: Thu Jul 26, 2012 12:18 pm    Post subject: Reply with quote
Thank you for all of the replies and pictures.
Bill - no worries. I have part of the information I need. Have fun working on your wife's ride.
Next question, were all of the relays originally manufactured by Hella? Any other original manufacturer's used?
It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history.
356JAEGER
356JAEGER is offline
PostPosted: Thu Jul 26, 2012 12:13 pm    Post subject: Reply with quote
Jack,
Most likely the reason for the 4th tang on the flasher. Very nice.
Regards,
Joel Jensen
When in doubt, think about it..
The outcome of a project is directly proportional to its preparation.
jjjjack
jjjjack is offline
PostPosted: Thu Jul 26, 2012 12:03 pm    Post subject: Reply with quote
356JAEGER wrote:
Thanks Jack,
That would appear to verify the change from the wired 4 prong to the 3 prong socket type occurred at the 54 model. The updated one now available is far superior to the originals functionality. You can actually hear it working and it's never erratic in it's behavior. One of the highly recommended upgrades for your car if you drive it.
I think if I "upgraded" I'd loose my entertaining little stalk indicator:
Mine makes a nicely audible clicking noise, but, yes, it tends to slow at low idle!
Jack Stenner
IG:j.stenner
malibubill
malibubill is offline
PostPosted: Thu Jul 26, 2012 11:37 am    Post subject: Reply with quote
Given what is here now I don't think that a pic of mine from a 64 would be of much help (if I can even find it) so I'll spend Sunday fixing the wife's driver instead of looking for and photographing the unit I said I'd do earlier.
Bill Sampson
356 Registry Talk List Monitor 2004-2008
356 Registry Forum Moderator 2008
356 Registry Hall Monitor Award 2008
356JAEGER
PostPosted: Thu Jul 26, 2012 11:02 am    Post subject: Reply with quote
Thanks Jack,
Regards,
Joel Jensen
jjjjack
jjjjack is offline
PostPosted: Thu Jul 26, 2012 10:34 am    Post subject: Reply with quote
356JAEGER wrote:
Suboval wrote:
Do all of the 356's originally have a socket for the flasher relay?
Just a guess, but since these are listed as being for 54 - 65 application the use of a socket would seem likely. Prior to that someone familiar with early cars will have to chime in. Jack ?? What year is your 356 ?
My car is 1953 #51576. I don't know if my setup is original, but it all works properly (i.e., the little red light in the turn signal stalk lights and flashes properly). Mine does NOT have a socket. There are 4 wires as opposed to the typical 3 that are used in later cars. Evidently this is what is required on the earlier cars:
http://porsche356registry.org/356talk/topic.html?p=120401#p120401
Here's an image. The complete part number is Hella 91MS 2x18-20W 6V.
HTH,
Jack Stenner
IG:j.stenner
356JAEGER
PostPosted: Thu Jul 26, 2012 7:54 am    Post subject: Reply with quote
Regards,
Joel Jensen
Suboval
Suboval is offline
PostPosted: Thu Jul 26, 2012 7:26 am    Post subject: Reply with quote
MMW
MMW is offline
PostPosted: Wed Jul 25, 2012 3:51 pm    Post subject: Reply with quote
The one in my car has similar but not exact printing on it as the one from Zims. I am unsure if it is original or not. This unit is made by Hella.
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
roy mawbey
PostPosted: Wed Jul 25, 2012 12:34 pm    Post subject: Reply with quote
Suboval,
I believe my 59 A flasher unit is original or certainly 44 years old. I took a photo some time ago which I attach however apart from K32 and 6v 2x15w
I cannot read the other 2 parts of text. If its of interest I could look tomorrow in the car and advise. Let me know.
Roy
Roy
malibubill
PostPosted: Wed Jul 25, 2012 11:37 am    Post subject: Reply with quote
356JAEGER wrote:
Found this on Zim's site. Not OEM but is listed for 54 - 65 356 apps, so
perhaps the originals were all the same manufacture. Perhaps Bill can give the pertinent info printed on his original. My old ones were non functional and replaced by the updated units sold by Zims.
http://www.zimsautotechnik.com/acatalog/Turn_Signal_Flasher__6V__356.html#a644_2e613_2e342_2e00
I'll dig about in the garage and see if I can find it and then photograph it and let someone else verify (or not) its originality. I think I kept the thermal flasher (that arrived when we bought our car in Nov. 2001) when I put the electronic in for the LEDs. Guess I'll find out. It won't happen until Sunday though. Best Joel.
Bill Sampson
356JAEGER
PostPosted: Wed Jul 25, 2012 10:02 am    Post subject: Reply with quote
Regards,
Joel Jensen
Suboval
Suboval is offline
PostPosted: Wed Jul 25, 2012 9:47 am    Post subject: Reply with quote
malibubill wrote:
Dear SubOval:
If I misled you my sincere apologies. Best of luck on your quest. I might have what is an original 6 volt flasher from a 64 C. If you think that would help you please PM me and I'll search the garage and take photos for you.
I have no proof whatsoever but do, solely as a matter of personal faith, believe that the LED brake lights on our coupe have helped us to maintain the desired authenticity of the rear bumper when it has been closely approached by texting/drinking/reading SUV and truck drivers. But, that is admittedly speculation on my part.
Best
NP, Bill. All is good. Smile
I am just trying to get some information. Nobody seems to know. Sad
malibubill
PostPosted: Wed Jul 25, 2012 8:56 am    Post subject: Reply with quote
Dear SubOval:
Best
Bill Sampson
Suboval
Suboval is offline
PostPosted: Wed Jul 25, 2012 8:55 am    Post subject: Reply with quote
Sorry, I should have been more clear.
Yes, I am looking for information on ORIGINAL turn signal flasher relays.
