help frame horn busted
pafree
pafree is offline
PostPosted: Tue Aug 14, 2012 4:54 pm    Post subject: Reply with quote
i am sure you have read it already. http://www.thesamba.com/vw/forum/viewtopic.php?t=523587&highlight=frame+horn with the turbo, the car is going to be making a lot of torque so doing it right and adding some bracing from the frame horns up to the frame will help keep things in place. might even be a time to change over to IRS if you want.
bracing:
Mr. Unpopular
Mr. Unpopular is offline
PostPosted: Tue Aug 14, 2012 3:42 pm    Post subject: Reply with quote
Well you really need to pull the motor and trans to fix it, at least correctly. Don't fear it though, it's not too hard of a process. Is this a rail buggy?
The frame horn looks rusted from the inside out (which is common unfortunately), and they look like they've bent down from "abuse", so patching them isn't going to help. Best bet is to cut them off and weld custom ones on. Berrien buggy sells a kit. I just went to the web site (which is new, they have new owners) and couldn't find the kit. Their prices and quality are usually pretty good.
"In any racing engine, the nearer you are to it disintegrating, the better it's performance will be"
-Keith Duckworth, creator of the Ford/Cosworth DFV
Shadowcat95
Shadowcat95 is offline
PostPosted: Tue Aug 14, 2012 11:50 am    Post subject: help frame horn busted Reply with quote
help!!! how do in fix this im freaking out!!! i dont want to have to pull the engine and the entire transmition
2012-08-14_12-35-32_366 by Shadowcat95, on Flickr
2012-08-14_12-35-41_570 by Shadowcat95, on Flickr
I hate rust. simple as that.
http://www.thesamba.com/vw/forum/viewtopic.php?t=488382
