replacement headlight switch issue
telford dorr
telford dorr is offline
PostPosted: Mon Apr 11, 2016 9:46 am    Post subject: Re: replacement headlight switch issue Reply with quote
Only a good headlight switch will do that...
'71 panel, now with FI
More VW electrical at http://telforddorr.com/ (available 9am to 9pm PST)
scrivyscriv
Samba Electrician
scrivyscriv is offline
PostPosted: Mon Apr 11, 2016 9:35 am    Post subject: Re: replacement headlight switch issue Reply with quote
So I should be glad that my green dash light comes on with parking lights and turns off when headlights are on?
Now if I could just get it to dim the dash lights.... Not talking
Robert in Memphis
Engine rebuild thread
airschooled
Air-Schooled
airschooled is offline
PostPosted: Mon Apr 11, 2016 9:28 am    Post subject: Re: replacement headlight switch issue Reply with quote
telford dorr wrote:
…you will probably get tired of seeing that green dash light on any time the headlights are on...
I can confirm that over 37,000 miles.
www.airschooled.com
telford dorr
PostPosted: Mon Apr 11, 2016 8:26 am    Post subject: Re: replacement headlight switch issue Reply with quote
No, it won't cause it to "short out" - the indicator lamp is an insignificant load. But you will probably get tired of seeing that green dash light on any time the headlights are on...
[email protected]
cerplunk@aol.com is offline
PostPosted: Mon Apr 11, 2016 7:34 am    Post subject: Re: replacement headlight switch issue Reply with quote
Spent a lot of time messing around with this issue, ended up having to pic-up a used 1968 switch for my 1969 bus.
Here is what I learned:
For my year, 1969, and I believe 1968, 1969, 1970 all share the same switch (?) there must be the tab 57 on the switch! - this is to make the "running lights only" on position (half pull out on switch). The replacement/aftermarket switches are shaped very different, without a tab 57, using the same part number (311 941 531 A)? I was told one can "double up" the wire that is supposed to go on the 57 tab to an existing tab, but it may cause the switch to short out eventually.
telford dorr
PostPosted: Mon Aug 26, 2013 10:24 am    Post subject: Reply with quote
Nope. Generic, small single pole, single throw relay with a 12 volt coil will work. Use the connections described above, using good 1/4" female blade terminals.
Side note: know the difference between a good terminal and the crap terminals? Pull / pry the plastic insulating sleeve off of the terminal and look at the metal tube the wire fits into. Is it really thin and easily bent? Crap terminal. The good ones are heavy duty metal - hard to bend. The excellent terminals have the joint welded so that there's no way for the terminal to open up and release the wire.
This is another case of "Buy the best and cry once". Crap terminals are what give crimp-on terminals a bad reputation. If you ever use the excellent welded seam type terminals, you'll never go back to anything else.
airschooled
Air-Schooled
PostPosted: Mon Aug 26, 2013 12:51 am    Post subject: Reply with quote
Shahn wrote:
Has anything changed for us in the headlight switch replacement department?
I need a headlight switch for a 72 and I'm going to be really anal about the little things like my dash lights working. I'm willing to go new or used as long as it functions like the original.
The suppliers I have found so far don't appear to have the correct switch with the #57 terminal.
I just emailed WW asking about any switches that have #57. I just found out tonight that my green indicator light SHOULDN'T be on all the time, and that my instrument lights should actually dim! WOAH!
Telford- is there a specific Bosch cube relay we should use? Any tips for connections for us electrical newbies?
www.airschooled.com
Shahn
Shahn is offline
PostPosted: Wed Jan 23, 2013 1:37 pm    Post subject: Reply with quote
ccpalmer
ccpalmer is offline
PostPosted: Sat Aug 25, 2012 8:28 am    Post subject: Reply with quote
I'd love to have an OG switch but for now I'm going to be happy just to be able to drive at night without worrying about losing my lights! Shocked First a regulator, then a switch... seems to be a recurring issue! Confused
'71 Westy
telford dorr
PostPosted: Sat Aug 25, 2012 8:23 am    Post subject: Reply with quote
I agree also - that's why, because of dimmer failure, I bought a good used switch for mine . But if you just can't get one, then there is an alternative...
busdaddy
busdaddy is offline
PostPosted: Sat Aug 25, 2012 7:58 am    Post subject: Reply with quote
Agreed, but just plugging the wire onto the correct terminal would be soooo much easier Razz
Слава Україні!
telford dorr
PostPosted: Fri Aug 24, 2012 9:41 pm    Post subject: Headlight switch, no terminal 57, parking light in dash Reply with quote
Other than 'used', a correct headlight switch with a terminal 57 is hard to find.
You can emulate the missing pin with a Bosch cube relay, if you really want that indicator light to work. Wire the coil of the relay between the taillight circuit (58) and the headlight circuit (56). Wire one relay contact to power (30). Wire the other relay contact to the dash indicator light (was 57). Done!
When the switch is pulled out one click, taillight power will flow through the relay coil to ground via the non-illuminated headlights, activating it and lighting the dash indicator. Pull two clicks and the relay will have 12 volts on both relay coil ends; the relay deactivates, and the indicator light goes out.
busdaddy
busdaddy is offline
PostPosted: Fri Aug 24, 2012 8:28 pm    Post subject: Reply with quote
ccpalmer wrote:
busdaddy wrote:
Interesting, does it have terminal #57 and does it really only work when the parking lights only are on?
Nope. Directions say to plug that wire into #58 also.
Dammit! Confused Keep hoping for a correct early bay switch..............someday........ Smile
Слава Україні!
ccpalmer
ccpalmer is offline
PostPosted: Fri Aug 24, 2012 8:22 pm    Post subject: Reply with quote
'71 Westy
busdaddy
busdaddy is offline
PostPosted: Fri Aug 24, 2012 8:15 pm    Post subject: Reply with quote
Слава Україні!
ccpalmer
ccpalmer is offline
PostPosted: Fri Aug 24, 2012 3:29 pm    Post subject: Reply with quote
Update:
I ordered a new headlight switch from WW. It came with a note saying that due to quality issues with Brazilian switches they have a new source for their switch. (website says OEM)
I just installed the new switch and it does appear to be of better quality than the old one just from looking/feeling. I'm 90% sure I ordered my last switch from WW about 4 years ago. That one (which failed) had a part number - 211941531E - stamped on it. This new switch does not. But WW included directions on how to make it work on 68-79 Buses.
So I'm certainly not surprised my old one failed! Just thought I'd give a heads up.
Disclaimer - I do drive on a lot of crap-ola roads and like I said my Bus gets very humid at times...
'71 Westy
ccpalmer
ccpalmer is offline
PostPosted: Mon Aug 20, 2012 5:33 am    Post subject: Reply with quote
Also - does anyone know if there is a difference between this:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211941531E
(says OEM German)
and this?
http://www.busdepot.com/211941531e
(says it works better than other replacements for a '71)
'71 Westy
ccpalmer
ccpalmer is offline
PostPosted: Mon Aug 20, 2012 5:27 am    Post subject: replacement headlight switch issue Reply with quote
Just wondering if anyone else has had this issue. I installed a new late-Bay headlight switch on my '71. Worked great for a few years; now occasionally when I'm driving on dirt roads at night my headlights will shut off. Just the headlights, not the running lights. I can get them to turn back on my grabbing the headlight switch and pulling on it a bit.
I assume it is losing contact inside the switch on bumps. Not good!
It does only happen when I've been parked along a river in the evening until after dark. (but that's about the only time I drive the Bus at night...) And I know that the air gets very humid when I park near a river at night. I have had some other issues with regulators shorting out in the same situation... so I have to wonder if maybe moisture is getting inside the headlight switch?
No big deal - I'll just order a new one - but it is a peculiar problem and I wonder if anyone else has had issues with replacement headlight switches.
Thanks!
'71 Westy
