Lowering the Front End
flamed74vwthing
flamed74vwthing is offline
PostPosted: Thu Nov 27, 2003 12:36 pm    Post subject: Reply with quote
mine is about 6" lower than stock and on 17" wheels I used a bug beam and ghia spinndels with weld in adjusters and can drop south till the wheels set on the tires at the hight it sets at now it rides great with little trouble turning.
sixfootdan
Samba Smartass
Location: \Lo*ca"tion\, n. 1. The act or process of locating.
sixfootdan is offline
PostPosted: Sun Oct 12, 2003 1:30 pm    Post subject: Reply with quote
That is way more work than changing a Beam. Also then you have VIN # issues.
Schrodinger's cat walked into a bar and it didn't.
GO SEAHAWKS!!!
farmersean
farmersean is offline
PostPosted: Sun Oct 12, 2003 1:14 pm    Post subject: Reply with quote
How about the thing body bolting on to a ghia chassis? I've been told that this is the way to go if you want to slam the front end to the ground.
TimGud
TimGud is offline
PostPosted: Wed Oct 08, 2003 7:15 am    Post subject: Reply with quote
A beetle ball joint front end will bolt up. I believe it gives about a 2" drop.
farmersean
PostPosted: Tue Oct 07, 2003 6:13 pm    Post subject: Lowering the Front End Reply with quote
What is the best way to lower the front end? Does the beetle front end bolt right up? How much lower will it make it? Any info on this would be greatly appreciated.
