57 with a 7 " narrowed beam ! HELP !
krusher
krusher is offline
PostPosted: Sat Nov 30, 2024 8:59 am    Post subject: Re: 57 with a 7 " narrowed beam ! HELP ! Reply with quote
just buy the wheels and tyres and then get some long bolts (3 per wheel would do) and behind the wheel use nuts to make up 2" spacers on either side, you will see then how it looks. Adjust the spacer nuts in width till you like it. Differant wheels have different offsets. so always worth a mock-up.
(06:31:07) RoachGhia: "i drink dick way too fast"
CUBA
CUBA is offline
PostPosted: Sun Apr 20, 2014 8:58 am    Post subject: Reply with quote
8" Beam on 3.5 Ecro's Cool
JOKE^ Laughing
6" on 145's and Gas Burners.
Kraftfahrer
Kraftfahrer is offline
PostPosted: Sat Apr 19, 2014 7:18 am    Post subject: Reply with quote
Sorry it took so long, had some other issues in the meanwhile. Here´s the new 3" axle from DOG BACK Beam Performance with 4,5" Sprintstars from BBT and Firestones 145 SR 15.
Kraftfahrer
PostPosted: Sat Feb 09, 2013 2:46 pm    Post subject: Reply with quote
hey James and brownie, thanks for the nice pics !
It looks awesome ! 3" is the perfect choice for us , we already ordered the 3" beam. I will post update pics as soon as I can.
cheers,
Chris
brownie
brownie is offline
PostPosted: Sat Feb 09, 2013 7:31 am    Post subject: Reply with quote
4 inch beam with disc brakes just to give u a idea,,if u ever go with disc u gonna lose some thats why i went with a 4 inch
56 oval
57 single cab
65 ez camper
wife=72 squareback
http://beachesbugsbuses.com/
https://www.facebook.com/germanmetalvwclub
fresno james
fresno james is offline
PostPosted: Fri Feb 08, 2013 4:26 pm    Post subject: Reply with quote
I'm running a 3 inch beam with offset shock towers on "Spanky 56" ragtop with BRM's and 145/65 continentals (smart car ) & 185/65 rear tires here..
I do have/ am running the "zero offset" disc brake kit from AC industries at all fours on the car and not drums.....
But it should look about the same ...
I like 'em "tucked' , But not looking and handling like a tricycle ... Laughing
3 to 4 inch beam is all "Most" would ever need to use without looking goofy and get a good "tuck" IMO ... Wink
Here's "Nunzio 57" with a four inch beam and sprints running 155 / 60 continentals in front and 165/80 in the rear on drum brakes ...
With the four inch , You can definitely tell I am slightly more "tucked" on the vert than the oval ...
In the end it's just a matter of preference ... the 3 and four inch beams handle about the same ... the offset is actually a little less on sprints (more tuck) than on Brms by about 1/4 or 3/8 IIRC ...
"El Roacho's" beam on the black vert is a six inch I believe ...
Some more food for thought if using sprints to stay 3-inch .... Smile
FJ Cool
JP Kustoms
contact info. [email protected]
Kingman AZ
Kraftfahrer
PostPosted: Thu Feb 07, 2013 3:49 pm    Post subject: Reply with quote
Thanks for the pic Magnate, but I´m looking for 3" beam pics.
Still a very nice pic, though.
Chris
Magnate
Magnate is offline
PostPosted: Thu Feb 07, 2013 12:12 pm    Post subject: Reply with quote
5" beam 17x7 front
rear 19x7
1954 euro oval patina sold
1959 11 window mango sold
1961 type 1 pan scraper patina
1963 type 1 sold
1961 chevy nomand
1972 chevy donk on 26's sold
Shane1914
Shane1914 is offline
PostPosted: Sat Jan 26, 2013 1:04 pm    Post subject: Reply with quote
Thank You,
It is not the best picture. I can post some better ones.
Let me know.
1956 Oval
Kraftfahrer
PostPosted: Sat Jan 26, 2013 12:26 pm    Post subject: Reply with quote
Shane, that looks awesome ! The stance is perfect ,too !
Shane1914
PostPosted: Sat Jan 26, 2013 8:25 am    Post subject: Reply with quote
drum brakes.
stock wheels.
135r15
3" narrowed beam.
I will be working on my car today. I can get some different pics if you need.
1956 Oval
Kraftfahrer
PostPosted: Sat Jan 26, 2013 6:07 am    Post subject: Reply with quote
@Slalombuggy: We keep the original drums , no disc brakes. We just love the look of a narrowed beam, that´s all.Rims are 4,5 Sprintstars. Lowering the car is not a problem, we will have an adjustable beam. Thanks for the pic, though.
Vwclap & Ovalshark: thank you very much !
vwclap
vwclap is offline
PostPosted: Sat Jan 26, 2013 3:56 am    Post subject: Reply with quote
You will find the look you are looking for in that tread....Not oval but early bug.
I am in the process to do the same on my 62 with 2 inches narrow beam, 2 1/2 inches dropped spindle. 145 front and 205-65 15 rear
http://www.thesamba.com/vw/forum/viewtopic.php?t=3...p;start=60
Claude
Claude
cox 1956, 1962 et 1975
Split panel 1963
Samba 21 fenetres 1966
Ghia 1968
Sport Ghia 73
West 1970
Jetta 1992
Jetta TDI 2015
West Multivan 2002
ovalshark
ovalshark is offline
PostPosted: Fri Jan 25, 2013 9:09 pm    Post subject: 3" Reply with quote
Mine has a 3" beam. https://www.thesamba.com/vw/gallery/pix/944594.jpg
slalombuggy
slalombuggy is offline
PostPosted: Fri Jan 25, 2013 5:40 pm    Post subject: Reply with quote
My Oval with Sprintstars and a narrow beam. Front fenders are stock width just have a big lip on the inside for aerodynamics.
Are you running disk brakes? Why do you need a narrowed beam with stock width wheels? I've lowered lots of cars 4-5" and run stock beams and wider tires that what you plan on.
brad
Kraftfahrer
PostPosted: Fri Jan 25, 2013 4:55 pm    Post subject: Reply with quote
Thanks for the link ! I only found 2 cars with 3" N.b´s ...but we already decided for 3" or 3.5".
cheers,
CHRIS
stale air
stale air is offline
PostPosted: Fri Jan 25, 2013 12:49 pm    Post subject: Re: 57 with a 7 " narrowed beam ! HELP ! Reply with quote
Kraftfahrer wrote:
So fellas , show your 3" narrowed beams !
Check out this thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=156322&highlight=narrowed
Kraftfahrer
PostPosted: Fri Jan 25, 2013 12:22 pm    Post subject: Reply with quote
3" narrowed beam, anyone ??
Center Pin
Center Pin is offline
PostPosted: Fri Jan 25, 2013 10:03 am    Post subject: Reply with quote
Wow! It's a hover car!
Kraftfahrer
PostPosted: Fri Jan 25, 2013 1:54 am    Post subject: 57 with a 7 " narrowed beam ! HELP ! Reply with quote
No, I did not put that crappy beam there, It was already on the car when we bought it. You can´t even see the wheels ! It was pure hell to even drive it in the garage... dunno why people do such extreme frontbeams.
It´s my wifes car and we´d like to install a 3" narrowed beam with 4,5 sprinstars and 145´s up front.
We really don´t don´t how it would look like that´s why we need some pics
of Ovals with 3" beams with Sprintstars or 4,5 inch wheels in general.
... just to see the difference and the overall look !
I want it to look almost stock.
That´s the formerly agave green oval but it was resprayed in "samtgrün" in the 70´s. It sat in storage for more than 30 years.
