Panel flexing advice needed
skills@eurocarsplus
Samba Peckerhead
PostPosted: Sat Mar 16, 2013 1:37 pm    Post subject: Reply with quote
if the panel came unglued/unwelded, you can use panel bond to re attach it. often times when doing work to old cars, the factory glue will give up. if it was crashed in that area, it could have released the glue/welds once you have brought it back to straight
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
Thrasher22
Thrasher22 is offline
PostPosted: Sat Mar 16, 2013 10:45 am    Post subject: Reply with quote
Can't see from the inside, there is an interior (metal) panel in the way.
Good idea on pulling the filler, I hadn't thought of that being removable. I'll do some poking around this afternoon and see what I can find. Thanks guys!
busdaddy
busdaddy is offline
PostPosted: Sat Mar 16, 2013 10:22 am    Post subject: Reply with quote
There are a couple of spots that are (were) welded or bonded in there, you'll have to pull the filler to look (should be changing that anyways Wink ).
Слава Україні!
fusername
fusername is offline
PostPosted: Sat Mar 16, 2013 10:19 am    Post subject: Reply with quote
pretty sure the filler hole itself adds a bit of structure. have you looked from inside the b us? I think there is only trim panels between you and seeing that sheet from inside.
[email protected]
Need something custom bent up? shoot me an email, maybe we can make it work!
FORSALE: Thrust cut T4 and 1.9 main bearings
obnoxiousblue wrote:
Maybe Ben Pon's ghost comes and vomits NOS stampings for your bus, but not mine!
Thrasher22
PostPosted: Sat Mar 16, 2013 9:41 am    Post subject: Panel flexing advice needed Reply with quote
I've gotten rid of "most" the flexing/oil canning in my rear panel, except around the gas cap, where there is quite a bit of movement. If I push on the metal I can hear a "ping" sound which sounds like its trying to catch something (see video).
Is there something that the panel should be bonded to back there? If I could figure out exactly where the supports are I'd ideally just drill a hole and weld it in place. I need to use some filler lower down in the panel where I welded in a large patch, and I'm worried that someone will lean up here causing the whole panel to flex a little and crack the thin layer of filler below.
Any tips? Tricks? I've done quite a bit of shrinking on the rest of the panel already, and I think this area is too wide to do the same treatment.
