Crestrider Samba Member
Posted: Sat May 11, 2013 11:41 am Post subject: |
Ok, thanks very much for taking the time to post.
All the best. |
WI sportmobile Samba Member
Joined: August 10, 2010 Posts: 268 Location: Waukesha, WI
Posted: Sat May 11, 2013 11:29 am Post subject: |
Crestrider wrote: |
Hi
Cheers for the reply, I have 4 male terminals 2 pos and 2 neg
Both pos are now used and one neg.
So what I should do is get a connector and join the red pos wire from the Pertronix to the black wire that leads to solenoid and auto choke (effectively all 3 wires off the pos 15 terminal?
Thanks |
No The best option here is to get some three male spade termanals for the pos and neg of your coil for a total of six. This way you will not have to splice or crimp any wires. _________________ 73 VW T2 Sportsmobile T4 1800 dual webber ICT's
06 TOY Tacoma TRD
Don't mess with the DNR.
"Bargain hunter becomes the bargain hunted." |
Posted: Sat May 11, 2013 11:18 am Post subject: |
Hi
Thanks |
Posted: Sat May 11, 2013 11:08 am Post subject: |
They do sell spade connecters that allow you to "piggy back" off another spade. Look at your FLAPS. You may have to cut the choke wire and crimp one of these spades on there. I had the same issue once. Do you currently have 3 male spade terminals on the pos 15 and neg 1 of the coil? _________________ 73 VW T2 Sportsmobile T4 1800 dual webber ICT's
06 TOY Tacoma TRD
Posted: Sat May 11, 2013 10:24 am Post subject: Another Pertronix wiring question |
Hello, first post here so hello first of all.
I have a 71 bay 1600 and a Karmann Ghia (but the Ghia is another story)
I only got the bay a month ago and plan on using it over the summer and then starting a resto.
I've had a few issues with backfires and loss of power so set up the timing and all was fine however a trip out on Friday led to a breakdown and closed points.
So I purchased and fitted a Petronix igniter but I'm a little confused by the wiring, I've had a look and seen a few questions on here already but couldn't find anything specific to help solve my problem so here goes.
Install: removed condenser, points and fitted kit ~ black wire to negative ~ red wire to positive. However I had to remove the black wire which splits and goes to the solenoid and automatic choke.
With the red wire from the Pertronix and the other red wire (starter) connected there now isn't a positive terminal for the black wire. That's where I'm confused because without this wire connected the engine stars and runs sweet but I'm concerned I should have the black wire attached too?
Any help and tips appreciated.
Thank you |
