Throw out bearing adapter collar?
JiI
JiI is offline
PostPosted: Tue May 30, 2017 6:12 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Thanks! Just what I was looking for! Very Happy
Jeff
yamaducci
yamaducci is offline
PostPosted: Tue May 30, 2017 5:24 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
JiI wrote:
Who sells the press-in adapter collar? Need to get my T4 engine to work on my old swingaxle tranny. (1961 I think)
Jeff
Aircooled.net
-John Cox
My 2498 Turbo Re-Build Thread: http://www.thesamba.com/vw/forum/viewtopic.php?p=5578697#5578697
3rd Brake Light Safety Stars- I still have a couple with blue light left. Email me if interested.
JiI
JiI is offline
PostPosted: Tue May 30, 2017 12:55 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Jeff
epayne611
epayne611 is offline
PostPosted: Fri Sep 16, 2016 12:19 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Well I didn't think my little welder would have the penetration for the cross shaft, so I took modoks advice and called Rancho, explained what I had done. The guy was really helpful, said they use the same kit except they re-weld the cross shaft.
They appear almost identical, the clocking is a bit different so perhaps a different batch...
Anyway it's installed and one less thing I have to worry about on road trips. Thanks for the help everyone.
yamaducci
PostPosted: Tue Sep 13, 2016 7:47 am    Post subject: Re: Throw out bearing adapter collar? Reply with quote
The gold one has welds you can see but I would call them. They may offer to add some welds. Or call who you got the last one from. Either way make sure the welds are good or add them. you could just have your existing one re-welded. That is what I would do. It would take me 5 minutes to fix that.
-John Cox
modok
modok is offline
PostPosted: Sat Sep 10, 2016 2:44 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Every SSC trans that was scrapped for the R&P had one, and a long arm. I'd call a trans builder. There should be quite a few around. If not then can also modify the one you've got.
epayne611
PostPosted: Sat Sep 10, 2016 12:32 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Thanks for all the input, I appreciate. I would definitely think twice before doing this conversion, but since the adapter collar needs a special puller to remove, it will stay on for now. I also like the way the clutch engages now, compared to the two previous old style bearings I had. Maybe that's in my head though.
Anyway since the collar is staying, does anyone have recommendations for a different cross shaft? I looked at ACNs, it looks the same as the one I have now but gold in color, although I know John sells good stuff:
http://vwparts.aircooled.net/HD-Cross-Shaft-Shaft-ONLY-1971-72-113-141-701E-p/113-141-701e.htm
CB performance has this one that looks beefier than the one I have:
http://www.cbperformance.com/product-p/4562.htm?CartID=3
I just pulled the engine again last night so plan on doing this now.
Thanks!
yamaducci
PostPosted: Wed Sep 07, 2016 11:48 am    Post subject: Re: Throw out bearing adapter collar? Reply with quote
I had an early bearing fall off only shifting like a Granny into second gear years ago. It put a hole in the trans case, ruined the forks, bearing, clutch and starter. When I went to stage 4 in my buggy I initially safely wired the bearing onto the forks but then swapped the new bearing and collar in for more reliability. I added the heavy duty forks. Welding them all the way around and adding more metal to reinforce them (Thanks Marktucky for that suggestion) I also added the long throw arm and it feels effortless. I have not run it yet but I am way more confident in the newer style. Some pics are in my gallery.
-John Cox
modok
modok is offline
PostPosted: Mon Sep 05, 2016 2:22 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Weld broke after a year or so?, only had a 1200lb sachs pressure plate.
I wish it had broke right away, but NO Shocked , broke in Wyoming!
It was back in 2009?
Sorry to scare you, but if getting a VW shaft in there solves your angle problem AND possibly avoids disaster of a weld breaking then yeah, I think you might want to try it.
mcmscott
mcmscott is offline
PostPosted: Mon Sep 05, 2016 12:43 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
^^^^^ This is good advice^^^^ I have built 1000's of transmissions and have seen more problems created with this than solved. There is nothing wrong with good oem crosshaft with the arms tig welded in place
There are no stupid questions, only stupid people,
68 Ghia
67 T-1
65 Notch
02 Mexican beetle
74 Thing
15 Long travel rail
07 Nomad
05 f-250
Dale M.
Dale M. is offline
PostPosted: Mon Sep 05, 2016 8:26 am    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Is that after market add on guide tube and late model throw out bearing... Umm... I think I would avoid it and return to original OEM parts, a lot of after market modification parts are not all they are cracked up to be... Some times someones better ideas are not...
Dale
epayne611
PostPosted: Mon Sep 05, 2016 7:06 am    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Well, that's not good. Modok how many miles did you have on it before it broke, and what was your application?
Looks like I'm pulling the engine again Crying or Very sad
Bruce
Bruce is offline
PostPosted: Sun Sep 04, 2016 9:29 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
I have seen aftermarket cross shafts with the splines cut clocked wrong. Compare yours with a genuine VW one. Better yet, put a genuine VW one in your gearbox.
modok
modok is offline
PostPosted: Sun Sep 04, 2016 8:57 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Don't trust the arm.
I bought the same kit, didn't do me much good, that weld broke 200 miles away from home.
epayne611
PostPosted: Sun Sep 04, 2016 8:20 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Yes that's the later fork, it came with the kit and was advertised as HD, although looking at my old one the welds are def less beefy. Hopefully it holds up. I ordered a longer bay window clutch cable, installed it but it was too long. So I installed another split bus cable and left it with just barely a couple threads. Popped the engine in, was able to adjust a few more threads so it's on there and shifting.
Long day, kind of a pain in the ass conversion.
66brm
66brm is offline
PostPosted: Sun Sep 04, 2016 3:36 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Did you change the throw out fork to the later style? Looks like the early one still there
Aust. RHD 66 Type 1
Aust. RHD 57 Type 1 Oval
modok wrote:
I am an expert at fitting things in holes, been doing it a long time
epayne611
PostPosted: Sun Sep 04, 2016 9:39 am    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Dale, engine has not been reinstalled yet...the throwout bearing is sitting out so far out that I'm pretty sure the clutch will be engaged and get burned up pretty quick. If you look at the second picture you can see how far forward on the guide collar it is sitting.
Wondering if I have installed something backwards or if the new throwout shaft is clocked differently and this is messing things up. Was thinking of getting the longer bay window clutch cable but this is something no one has mentioned anywhere about this conversion so it has me wondering if I've done something wrong....
Dale M.
Dale M. is offline
PostPosted: Sun Sep 04, 2016 7:43 am    Post subject: Re: Throw out bearing adapter collar? Reply with quote
Does clutch work ok?......... If so drive it..... Does not matter where wing nut is on cable as long as you have full thread engagement...
Dale
Howard 111
Howard 111 is offline
PostPosted: Sat Sep 03, 2016 10:17 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
It's hard to ignore, but I'll try! Very Happy
1973 Karmann Ghia
Turbocharged, Fuel Injected
http://www.thesamba.com/vw/forum/viewtopic.php?t=531270
epayne611
PostPosted: Sat Sep 03, 2016 9:31 pm    Post subject: Re: Throw out bearing adapter collar? Reply with quote
I just installed one of these adapter in my 66 bus. Something is not right- the clutch cable is barely threaded on and the throwout bearing is sitting pretty far away from the housing, like it would already be partially engaging the clutch.
Do I need a different arm, or longer clutch cable? Haven't seen this mentioned anywhere else, did not have this issue with the older style.
Ignore the blue webbing I used it to pull the clutch lever while I threaded the wing nut.
