1961bluebug Samba Member
Joined: November 11, 2002 Posts: 1137 Location: Czech Republic, Europe
Posted: Thu Aug 17, 2017 12:57 am Post subject: Re: 1835 Single port build! |
very valid point, is there only for initial adjustment of the fuel pump output (by shortening the push rod). Will not be there after this is sorted and remains of 1 yr old fuel in the tank run out. The fuel filter is located under the tank in usual location). _________________
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold) |
FreeBug Samba Member
Joined: March 12, 2012 Posts: 4277 Location: deepest, darkest Switzerland
Posted: Wed Aug 16, 2017 2:03 pm Post subject: Re: 1835 Single port build! |
1961bluebug wrote: |
Well on my side not really. I started the engine just yesterday to find out a small oil leak from behind flywheel area so usual suspect is cam plug or inproperly tightened oil galley plug. So the engine goes out on Monday for a repair.
Small progressive changes were made: stock weight 8 dowel flywheel, other exhaust. Starting well, holding nice idle, very rich as my mixture screws are in very basic adjustment. But it will be all sorted.
PLEASE for the love of everything Volkswagen, get that fuel pressure regulator/filter out of there!
If it leaks, it would flow onto the distributor.
It looks like it is mounted to the shroud, something is bound to vibrate loose.
I've seen too many of the remains of those things in burnt-out engine bays. Disaster waiting to happen. PLEASE!  |
tdrrally Samba Member
Joined: January 05, 2011 Posts: 181 Location: charleston,wv.
Posted: Wed Aug 16, 2017 12:09 pm Post subject: Re: 1835 Single port build! |
good to hear its coming along |
Posted: Wed Aug 16, 2017 7:18 am Post subject: Re: 1835 Single port build! |
|82x94|
Posted: Sat Apr 15, 2017 3:58 am Post subject: Re: 1835 Single port build! |
i know its been a year, but any updates? |
Posted: Sat Mar 19, 2016 12:27 pm Post subject: Re: 1835 Single port build! |
Matthew wrote: |
I see you switched carbs to Kadrons. Crank trigger + 019? |
I plan to break the engine in on conventional ignition as as soon the carbs are set up and I feel comfortable I´ll switch to full EDIS system. _________________
|82x94|
Zundfolge1432  Samba Member
Posted: Fri Mar 18, 2016 5:00 pm Post subject: Re: 1835 Single port build! |
JRKman wrote: |
Anyone ever built a 1915 with ported single port heads, stock 8 doweled crank, 34 pict with machined venturi, w100/w110 cam, standard 1 3/8 header with hideaway, and an 034 distributor for a daily street driver?
Just curious since I have all the parts to throw one together but just don't see a lot on the forum on this type of combination.
What do you guys think?
-Josh
Edit:
running ICT's
92mm thick walls |
I did build this engine for a 71 bus a few years back and to make it worse I used a stock bus exhaust. As a few have said it runs out of steam early but it pulled hard off the line. I used a stock cam and dual relief Mexican universal case, if you need low end torque just to putt around its interesting and cheap to build |
Matthew Samba Member
Joined: January 29, 2004 Posts: 1760 Location: Eastern Tennessee
Posted: Fri Mar 18, 2016 4:40 pm Post subject: Re: 1835 Single port build! |
I see you switched carbs to Kadrons. Crank trigger + 019? _________________ 1965 Beetle sedan
Click to view image |
Posted: Thu Mar 17, 2016 5:08 am Post subject: Re: 1835 Single port build! |
my slow progress
|82x94|
JRKman Samba Member
Joined: June 21, 2011 Posts: 291 Location: Portland, OR
Posted: Mon Oct 20, 2014 8:19 pm Post subject: |
Any ideas? _________________ 1969 Type I
House paint red
1835cc single port:
Scat C25, ICT's, SVDA |
JRKman Samba Member
Posted: Sun Oct 19, 2014 8:12 pm Post subject: |
Engines installed and broken in. Can't get it to idle right now with the ict's (60/140 jets). Gonna have to work on that. The idle speed screws want to be over 3 turns out. Thoughts? _________________ 1969 Type I
House paint red
1835cc single port:
JRKman Samba Member
Posted: Tue Oct 14, 2014 4:17 pm Post subject: |
Getting close
House paint red
1835cc single port:
JRKman Samba Member
Posted: Thu Oct 02, 2014 8:31 pm Post subject: |
So I went to set the endplay today. Just pushing/pulling the flywheel I get .010" with no shims. If I slightly rotate while i push/pull I get between .035/.045
What measurement am I supposed to go by? .010" seems a little tight with no shims... _________________ 1969 Type I
House paint red
1835cc single port:
GDOG57 Samba Member
Joined: March 19, 2006 Posts: 1066 Location: Gilbert,Arizona
Posted: Wed Oct 01, 2014 10:31 pm Post subject: |
Runs great. Just took it on a 400 mile trip to Jerome for the jamboree. Pulled the hills better than i hoped. Got excellent gas mileage. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
'57 type 2 panel ( L31 dove blue) project daily driver,Singleport 1955cc
'69 Squareback (L30A Royal Red) |
JRKman Samba Member
Posted: Wed Oct 01, 2014 8:49 am Post subject: |
Thanks! How happy are you with your 1955cc single port? Hows it run? _________________ 1969 Type I
House paint red
1835cc single port:
GDOG57 Samba Member
Posted: Mon Sep 29, 2014 10:45 pm Post subject: |
Your engine looks great,and just like my 1955cc singleport. Your 60 idles and 140 jets sound perfect. I think you will be close with that setup. _________________ '57 oval window deluxe,Agave green(L240) 2276cc w/51.5 IDA's
JRKman Samba Member
Posted: Mon Sep 29, 2014 10:38 am Post subject: |
I'll get a video of it for sure.
How does the jetting sound for the ICT's?
60 Idle, 140 Mains. Should be able to start it up for break in on these jets I'm thinking. _________________ 1969 Type I
House paint red
1835cc single port:
Posted: Sat Sep 27, 2014 10:25 am Post subject: |
Sweet. Let us know how it runs. Pics / video would be cool too _________________ 1965 Beetle sedan
JRKman Samba Member
Posted: Sat Sep 27, 2014 9:00 am Post subject: |
Here it is all built up.
House paint red
1835cc single port:
JRKman Samba Member
Posted: Thu Sep 18, 2014 9:47 am Post subject: |
Wouldnt that give me a deck hight of 0.030 possibly? Which would be 9.3:1 for the compression for the C25. Wouldnt I run into valve clearance issues here? _________________ 1969 Type I
House paint red
1835cc single port:
