Gene Berg Shifter for sale??
aeromech
aeromech is offline
PostPosted: Tue Jun 18, 2013 6:33 am    Post subject: Reply with quote
Here's some pics of a shifter I installed into a 1968 bus. It does have a base plate for sure and was a bitch to adjust even though all the shift components had been rebuilt including the transmission.
Airbus A319,320,321
DC9/MD80
BAe146
Fokker F28/F100
VW type 1 1962,63,65,69,72
VW Jetta
VW Passat
Jeff Geisen
Samba Chaplain
Jeff Geisen is offline
PostPosted: Tue Jun 18, 2013 3:59 am    Post subject: Reply with quote
... these shifters will exagerate worn out linkage bushings. They multiply the throw so if anything in the system is worn it will not work well for you. There are two bus shifters produced, one for the early and one for the late bus. Check the part # with Berg before you buy.
I Corinthians 4: 1 thru 5
‘63 ragtop - ‘68 single cab
Cptn. Calzone
Cptn. Calzone is offline
PostPosted: Tue Jun 18, 2013 3:28 am    Post subject: berg shifter Reply with quote
The best shifter when adjusted correctly.I have two, one in my 71westy and one in the sc.I have the sc adjusted correctly ad the shifting is excellent.You will be pleased.It adjusts same as stock, just move it around a bit and test drive.
71 westfalia
67 912 Porsche Quintilla
67 Single Cab aka my work horse
AlohaDaBus
AlohaDaBus is offline
PostPosted: Tue Jun 18, 2013 2:36 am    Post subject: Gene Berg Shifter for sale?? Reply with quote
Aloha gang! Im planning on buying a Gene Berg shifter from a friend who says he got the shifter a long time ago and it came from a 70s bus. My question is... Is there a bottom plate that goes with it? Or can i just install it and see if it works?? Is there a special way to install it... like does it have to be in neutral position to install the shifter?? Any help would be great... Much mahalos! (thanks) \m/
