shokwave2 Samba Member
Joined: February 02, 2010 Posts: 264 Location: Wollongong, Australia
Posted: Sun Aug 18, 2013 11:58 pm Post subject: |
Well got a pack of 4 diodes for $1, tried installing just one and it's done the trick. Thanks everyone. Although other guys have said their VDO tacho came with a diode included in the package. Mine didn't, oh well. _________________ Drive it like you stole it. |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13947 Location: White Mountains Arizona
Posted: Sun Aug 18, 2013 6:59 pm Post subject: |
Mine only needed the one diode, I have a small box of them. Any diode that can handle a couple of amps is fine. _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Dale M. Samba Member
Joined: April 12, 2006 Posts: 20807 Location: Just a tiny bit west of Yosemite Valley
Posted: Sun Aug 18, 2013 1:22 pm Post subject: |
Radio Shack ..... Walk in, drop $1.98, walk out with diodes...
Dale _________________ “Fear The Government That Wants To Take Your Guns"
Eric Hodges Samba Member
Posted: Sun Aug 18, 2013 12:26 pm Post subject: |
Yup.
Or 1N4001, 1N914, ... any diode. _________________ '74 Super, worn, becoming DD |
Posted: Sun Aug 18, 2013 3:25 am Post subject: |
Quokka42 wrote: |
Yes, that can help. two diodes such as 1N4004 back to back should fix it. |
So i should install 2 diodes, not 1? I can't find 1N4005 on Jaycar's website, so would 2 x 1N4004's be equal? _________________ Drive it like you stole it. |
Quokka42 Samba Member
Joined: December 02, 2010 Posts: 3117 Location: Melbourne, Australia
Posted: Sun Aug 18, 2013 2:36 am Post subject: |
Yes, that can help. two diodes such as 1N4004 back to back should fix it. The reverse breakdown should be enough to smooth it, otherwise, buy a couple of Zeners of 15V or more and do the same.
If it is an electronic ignition, you can also try sticking a condensor across it. _________________ There has only ever been one man who was perfect, and they nailed Him to a cross. |
Posted: Sun Aug 18, 2013 2:31 am Post subject: |
Cheers, will do. _________________ Drive it like you stole it. |
longboard511 Samba Member
Posted: Sun Aug 18, 2013 2:25 am Post subject: |
im sure sometimes they need a diode fitted in line do a search on jumpy rev counter im sure you will find the info |
Posted: Sun Aug 18, 2013 2:10 am Post subject: Tacho jumpy at idle unless multimeter connected?!? |
Just installed a VDO tachometer today and hooked up a multimeter to check the accuracy. It was spot on reading 850 at idle and spot on when reved. But when i removed the multimeter the tacho showed higher and jumping around at idle, anywhere from 1100-1500. All i did was attach the multimeter to - side of the coil and to a ground, and the tach works fine. Electrics are 12V, points, alternator, tacho is wired to the coil. Is this a grounding issue somewhere, with either the coil or tacho? _________________ Drive it like you stole it. |
