70 vw beetle heads, need some opinions
old DKP driver
old DKP driver is offline
PostPosted: Wed Oct 23, 2013 6:13 pm    Post subject: cylinder heads Reply with quote
The reason the cylinder heads and pistons have the combustion' Pattern'
is :The cylinders to case from barrel to barrel is uneven and, Also your rings
are Kaput and/or pistons.
To really find out the problem you will need to
Check depth on ALL 4 spigots on the heads
cylinders to case.
Oily and running rich in your pictures Idea
V.W.owner since 1967
jrny99
jrny99 is offline
PostPosted: Wed Oct 23, 2013 5:31 pm    Post subject: Reply with quote
72Pstroke wrote:
Are the pistons coming out past the top of the cylinders?
no they are not.
72Pstroke
72Pstroke is offline
PostPosted: Wed Oct 23, 2013 5:14 pm    Post subject: Reply with quote
jrny99
jrny99 is offline
PostPosted: Wed Oct 23, 2013 3:23 pm    Post subject: 70 vw beetle heads, need some opinions Reply with quote
it looks like the heads were being hit by the pistons, can anyone chime in with some advice.
