Capriacci Samba Member
Joined: February 15, 2011 Posts: 298 Location: Brazil
Posted: Mon Jun 15, 2020 10:21 am Post subject: Re: Barndoor spindle question |
Wow! Thanks guys! |
Pi2 Samba Member
Joined: February 16, 2014 Posts: 14 Location: Germany
Posted: Mon Jun 15, 2020 7:19 am Post subject: Re: Barndoor spindle question |
Hello
yes I think this is the point. If you look in a later repair manual from 1959, you will find the same cotton grease seals without this extractor ring, but with a better instruction how to prepare the seasl and which grease specification you have to take (high temperature).
Greetings
gatorwyatt wrote: |
Would that ring be installed to prevent a majority of cover for the inner wheel bearing so the grease doesn’t overcome the wheel seal? Remember...these were designed with cotton grease seals. |
Pi2 Samba Member
Posted: Mon Jun 15, 2020 7:11 am Post subject: Re: Barndoor spindle question |
Thank you very much Crashbox
Pierre
Crashbox wrote: |
Here you go, the "elusive" extractor ring, part number 211 405 649:
Outer diameter 72mm:
Inner diameter 55,5mm:
Thickness 2mm:
Sits flush with the inner race of the wheel bearing:
gatorwyatt Samba Member
Joined: April 24, 2002 Posts: 1885 Location: Clearwater Fl.
Posted: Fri Jun 12, 2020 7:54 am Post subject: Re: Barndoor spindle question |
Would that ring be installed to prevent a majority of cover for the inner wheel bearing so the grease doesn’t overcome the wheel seal? Remember...these were designed with cotton grease seals. _________________ www.blastserv.com
wanted:
Nothing! |
mandraks Samba Member
Joined: November 28, 2004 Posts: 7117 Location: Lawrenceville, Ga
Posted: Wed Jun 10, 2020 7:13 pm Post subject: Re: Barndoor spindle question |
and the bearing was made in my old hometown of Schweinfurt. _________________ regards
Uli
Crashbox Samba Member
Joined: February 11, 2010 Posts: 41 Location: Germany
Posted: Wed Jun 10, 2020 3:41 pm Post subject: Re: Barndoor spindle question |
Thickness 2mm:
_________________ '50 Type 11C
'52 Type 21A
'62 Type 111
'71 Type 23-517, SO 72/3 |
sled Samba Member
Posted: Wed Jun 10, 2020 8:24 am Post subject: Re: Barndoor spindle question |
maybe check with Beefcake as he disassembles "The Lind"s NOS beam? _________________ drive your split. |
campingbox  Samba Member
Joined: November 14, 2000 Posts: 10249 Location: Petaluma, CA
Posted: Tue Jun 09, 2020 8:31 pm Post subject: Re: Barndoor spindle question |
I’m interested to see photos and measurements as well. I can’t recall having run across one before.
Interesting that they picture the inner bearing spacer without a step - was there a special spacer and a special wheel bearing seal to go with this extractor?
My 53/54 workshop manual mentions them using the spacer at various intervals. |
Pi2 Samba Member
Posted: Fri Jun 05, 2020 11:37 pm Post subject: Re: Barndoor spindle question |
Hello
I have the same Problem like you have had.
Have you got any Response?
Thanks for Information
Greetings |
Posted: Wed Sep 10, 2014 9:50 am Post subject: Barndoor spindle question |
Hello, can someone help me? I'm assembling the spindle/drum and the part nr 39 on the pic below is missed.
I would like to know if it's easy to find this part for sale or if it's possible to replace it with a regular washer.
Could someone please let me know the measurements of this part? Pics are welcome too...
Barndoor Spare Parts List call this part as a "extractor ring". But for me it seems like a spacer.
I really appreciate your help.
