Kasten68 Samba Member
Joined: March 26, 2005 Posts: 138 Location: Switzerland
Posted: Mon Dec 22, 2014 3:37 am Post subject: |
| Panelvan wrote: |
| EverettB wrote: |
| Buba wrote: |
| just one question, SC BD and ambulace BD's air cleaners are the same? |
As far as I know - yes.
I do not see why there would be any difference. |
Yes,sure they are the same  |
You're right
| D-train wrote: |
| screw on type not wingnut isn't it? |
I think no, but I've to control _________________ VW über alles ! |
Panelvan Samba Member
Posted: Mon Dec 22, 2014 1:31 am Post subject: |
| EverettB wrote: |
| Buba wrote: |
Yes,sure they are the same  _________________ http://rascal.skynetblogs.be/ |
EverettB  Administrator
Joined: April 11, 2000 Posts: 71996 Location: Phoenix 602
Buba Samba Member
Joined: February 23, 2003 Posts: 383 Location: Argentina
Posted: Sat Dec 20, 2014 5:45 am Post subject: |
great info!!
regards
Marcos _________________ 52 Ambulance
57 SC
57 Oval
60 SO23
60 Bug |
D-train Samba Member
Posted: Sat Dec 20, 2014 2:33 am Post subject: |
screw on type not wingnut isn't it? _________________ shiny paint doesnt make it worth any more |
Posted: Fri Dec 19, 2014 8:00 am Post subject: |
Some interesting similarities with parts used on my Type 122 engine and all parts are VW badged
Posted: Fri Nov 28, 2014 10:19 pm Post subject: |
| Brian_Mccue wrote: |
| Where are you guys finding the dates on them |
I looked at one of mine and could not find a date stamp.
It's possible I missed it.
My earlier "54/55" information was really just posting pictures of the 54-56 style rather than the 53 or earlier styles you also see in this thread.
I'll have to remember now they are late 1954-56 because of the Progressive Refinements pages I posted - The air cleaner style I posted with the 1-piece neck and the wing nut bottom went from 29 Nov. 54 through 26 Sept. 56. _________________ How to Post Photos
djfordmanjack Samba Member
Joined: June 15, 2009 Posts: 2404 Location: Graz, Austria, Europe
Brian_1952 Samba Member
Posted: Fri Nov 28, 2014 5:45 pm Post subject: |
Where are you guys finding the dates on them _________________ (20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
WANTED 52 parts and NOS sheet-metal |
Posted: Fri Nov 28, 2014 3:39 pm Post subject: |
concerning the unidentified part, it is definitely not home made. square weld nut, pressed dimples, elongated holes, black paint like on VW engine tinware/ air cleaner.
I straightened it out some what. I believe the ends should be straight.
Anybody knows what this is for ?
does this belong to the air cleaner or could this be an accelerator foot rest ? _________________ Hotrods, Fords, Veedubs and Triumph Twins !
54 Oval project
62 Dickholmer, Seeblau L360
67 1500 Käfer, og paint Lotus weiß L282 w/red interior |
Posted: Fri Nov 28, 2014 3:26 pm Post subject: |
cleaned it today. clearcoated the remnants of the original decal. I have a replacement repro decal, but I want to save the original and detail it later.
obviously the first design of the cleaner was a fail. moisture and condensed water can easily get into the oil bowl, rusting out the bottom, as can be seen in my oil bowl. oil sludge had trapped water.
probably why they changed the design to the larger top cover.
54 Oval project
Posted: Thu Nov 27, 2014 12:54 am Post subject: |
Mine is From 03/1953
Small détail on this area , maybe it could tell us "older... ect"
The hole is open
Posted: Wed Nov 26, 2014 4:59 pm Post subject: |
| djfordmanjack wrote: |
| Everett, D train and Panelvan, what are the Years of your trucks ? obviously panelvan's and my cleaner are of the same style and D train's and Everett's are. I reckon Everett, it's from a 55 truck ? thanx for getting the details on the stud. I can compare the dimensions with the stud from my cleaner, maybe they are different too. |
I do not have a truck, these are just loose air cleaners I own or have owned.
I believe the 26A one is from a Barndoor Truck but the other air cleaner may be from a later Bus since the wing nut air cleaners were used on all Buses for a while after the Barndoor era.
Some changes from Progressive Refinements are below.
Change from 2-piece pipe like what Brian posted above to the solid pipe:
End of wing nut air cleaner:
Posted: Wed Nov 26, 2014 3:46 pm Post subject: |
these are two that I've had in the past I actually still on the early one for my truck _________________ (20-024785)Ambulance (20-037784)truck (20-035850)panel
(20-035778)kombi
