Help - Adjusting Door Latch
Redlands-Paul
Redlands-Paul is offline
PostPosted: Mon Feb 09, 2015 3:14 am    Post subject: Reply with quote
Good call....
I've introduced myself and away I go Very Happy
Wolfgangdieter
Wolfgangdieter is offline
PostPosted: Sat Feb 07, 2015 8:56 pm    Post subject: Reply with quote
Try posting on www.speedsterowners.com
My CMC Speedster uses T1 Door Latch and striker But on the CMC the rubber door gasket is crucial in eliminating rattling doors. The CMC has a substantial steel perimeter frame that keeps VW pan/fiberglass body from flexing - does the Chesil have the same sub-frame?
CMC '57 Porsche Speedster Replica and Dolphin boat tailed full pan VW MOD-T Street Buggy
manxdavid
Location: David Jones, Anglesey, North Wales, UK. Manxclub #678.
manxdavid is offline
PostPosted: Sat Feb 07, 2015 12:28 pm    Post subject: Reply with quote
No idea mate, I'm a buggy guy. Maybe a post on vzi, the UK forum?
Redlands-Paul
PostPosted: Sat Feb 07, 2015 4:39 am    Post subject: Reply with quote
Long story..... Sometimes their helpful, more times they're not.
I've been waiting for 2 weeks now to just get a price on some spares that I need!
Do you know how interchangeable Chesil parts are with Speedster Clinic?
Thanks.
manxdavid
PostPosted: Sat Feb 07, 2015 3:18 am    Post subject: Reply with quote
Did you ask Chesil? http://www.chesil.biz/Chesil_Home.htm
MMW
MMW is offline
PostPosted: Fri Feb 06, 2015 7:45 am    Post subject: Reply with quote
Remove either the catch or the latch first & then see how the door closes. Is the door itself aligned properly? If not you need to adjust the hinges first. Once the door is properly aligned you can then work on the latch.
Before removing anything make sure there is not a couple of nuts or plates on the backside that will drop off into "nowhere".
Mic
1959 356 coupe
Missing the original engine 72488
Update - third pc. found!
Now just need the case halves.
1965 fenderless beetle
Dale M.
Dale M. is offline
PostPosted: Thu Feb 05, 2015 8:22 pm    Post subject: Reply with quote
Other than moving striker plate I don't know any way to adjust things.... Only solution I can think of for rattle is weather striping around door....
Dale
Redlands-Paul
PostPosted: Thu Feb 05, 2015 11:44 am    Post subject: Help - Adjusting Door Latch Reply with quote
Hi
I have a Chesil "Porsche" Speedster kit and need to adjust both doors as they rattle when closed and also slightly catch the body when closing.
I can't seem to find any details on the door latches and don't want to just dive in making things worse.
Do any of you recognise these and have any helpful advise on how to adjust them?
Thanks.
