Best TDI Turbo
Page: 1, 2, 3  Next
VanagonLand
VanagonLand is offline
PostPosted: Wed Feb 11, 2015 4:14 pm    Post subject: Reply with quote
Question
Question... Don't mean to HiJack just thought I'd ask as it's a similar question of O.P.
What Turbo upgrade would you guys recommend for a 1.9 AHU ?
I'm also looking to have a mechanical fuel pump built so looking for the Best Turbo Upgrade with the mechanical fuel pump combination.
Not looking for a rocket just a dependable good running that gets decent fuel mileage.
So who builds these type fuel pumps?
Along with what turbo upgrade any suggestions
Thanks
ironturtle
ironturtle is offline
PostPosted: Wed Feb 11, 2015 3:25 pm    Post subject: Reply with quote
FWIW, I run my 17/22 up to 1650F on long pulls at or exceeding 10,000 ft. 100,000+ miles on this turbine too. *knocks wood*
I put on the 17/22 when the stock 15 failed leaving a parking lot, and I was lucky to not hydrolock.
This is in a heavily tuned 03 Jetta, but turbos are turbos and my ALH has been a donor for the Vanagon in the back of my mind for a while Smile
1985 RWD Westfalia, brown with flowers, 2.1 transplant, 4 speed.
tclark
tclark is offline
PostPosted: Wed Feb 11, 2015 11:27 am    Post subject: Reply with quote
Interesting thread
Has anyone besides KarlM used a gt2052 in a vanagon
http://www.thesamba.com/vw/forum/viewtopic.php?t=616878&
Its quite popular on the tdiforms in the passenger cars
very inexpensive upgrade compared to converting ahu to vnt
moves more air compared to the k03/k04 hybird wastegate
I was curious how much of a lag and how much of a drop in egt's
any vanagon user saw compared to the k03 when used on the west coast style mountains
89 Westy with TDI AHU 1.9 manual lots of mods
85 GL 1.9, auto (for sold)
greebly
greebly is offline
PostPosted: Wed Feb 11, 2015 9:34 am    Post subject: Reply with quote
Now what you are inferring would be rare as hen's teeth. The N75 is at 80% duty cycle at onset ( on most of the time allowing maximum vacuum to the vane actuator) vacuum is decreased when the charge pressure sensor indicates that the boost is at what the engine map calls for. The N75 default position is closed. So you discovered an N75 valve that failed against the spring and was stuck in the open position allowing maximum vacuum to the actuator? I have seen some N75 failures, by far most of them with the waste gated turbo due to oil contamination from the boost line feeding the valve. That does not happen with the VNT with a clean vacuum supply unless someone removed the vent line from the filter and sucked up debris and moisture. Most N75 failures that I have seen or heard of with VNT turbos were electrical failures of the solenoid, not sticking valves and the rare ones that were stuck generally produced an under boost condition. Of course on the waste gated turbo which defaults to a closed waste gate a sticking N75 failure would lead to an over-boost situation. All over-boost conditions I have ever seen or heard of with the VNT was due to stuck vanes.
jackbombay
jackbombay is offline
PostPosted: Wed Feb 11, 2015 9:11 am    Post subject: Reply with quote
greebly wrote:
If you have never had sticking vanes why are you putting your finger down there? ( that sounds dirty doesn't it?) Literally and figuratively. Very Happy
Had an overboosting car in my garage recently, it turned out to be a bad N75, but its easy enough to check the vane mechanism so I did,
Gas struts to pop your top easily!
Pop Top strut kits now available for late Bay window Westies Smile
Samba ad here.
DIY artificial rain gutters (ARGs)
greebly
greebly is offline
PostPosted: Wed Feb 11, 2015 9:05 am    Post subject: Reply with quote
jackbombay wrote:
I have worked on many ALH TDIs over the years and none of them have ever had turbo coking issues
jackbombay wrote:
I just let the car cool for a bit and then check it with my finger.
jackbombay
PostPosted: Wed Feb 11, 2015 8:56 am    Post subject: Reply with quote
greebly wrote:
I am sorry if my opinion made you feel insecure .
Yes, your opinion has completely crushed my psyche, I am currently still in bed, I don't think I'm going to leave the house today, its all your fault, I hope you're happy with yourself.
greebly wrote:
I doubt I would stick my finger on a hot turbo to try and actuate the vanes Smile
Samba ad here.
tjet
tjet is offline
PostPosted: Wed Feb 11, 2015 6:40 am    Post subject: Reply with quote
Thanks for the link. I have 2 TDI's: an 02 Jetta w/auto (290k) & an 03 Golf w5-spd (220k). Both have been very reliable & all stock. I bought the Jetta about 10 years ago (I wanted a 5 speed but couldnt find one). The Golf I bought 5 yrs ago. I really wanted an 03 (last year of the ALH) & a 5 speed manual. These cars were banned in the northeast for a few years. When they come up for sale, they sell fast.
The only major failure I had was the auto trans on the Jetta. As for the engines, I've replaced both MAF sensors for overboost issues. The jetta did need a new vnt actuator & an "N75". Both go thru glow plugs about every 18 months (check eng light on my Golf right now)
I only use M1 TDT syn oil, which I replace between 9-10 k miles with OEM oil filters. I had the intakes cleaned on the last TB change - Intake was about 60% plugged at 230k. I drive the Jetta 100 miles daily. I am planning on a new turbo on my next TB change at 330k (going to get the 17) - I already have a PD150 intake for it.
By far the best mod I've done was to replace the failed auto trans in my Jetta with a Euro only manual 6-speed kit. My MPG avg's now at 50 (was around 40). It was an expensive mod tho - around $5k
I would drop an ALH into my Syncro as long as the gearing change wasn't so $$$$. I would also do the M-TDI mod at the same time. The driving RPM range on these engines is between 1800-2500. I shift at 3k & rarely go past 3100 rpm. My cruise RPM is 2300 rpm at 75 mph =50 mpg
Small issues on both engines: they never warm up until you drive it. The diesel fuel in my Jetta froze up last week - but it was my fault (see link)
Also, I do jockey the throttle daily on my was home to "work" the actuator before I shut it down.
http://www.thesamba.com/vw/forum/viewtopic.php?t=618616&highlight=
Here is the 6 spped kit I used. IMO the only way to justify the expense is if you have a failed auto. I almost traded it in for a new TDI before I decided on the kit. At the time (2 years ago) All new TDI's were tax free in CT
http://forums.tdiclub.com/showthread.php?t=373687
greebly
greebly is offline
PostPosted: Wed Feb 11, 2015 6:32 am    Post subject: Reply with quote
Jack, You keep using the term " it's not common" well I never stated that it was, asking how many Vanagons that have had TDI failures as if it would be a significant data point is facetious. I am positive that the number of Vanagons with TDI engines vs any other platform with that engine and turbo would be statistically insignificant. What does Suburu failures have to do with the best turbo for a TDI on a Vanagon? The VNT spools quicker. It also spins faster. Those two items are desirable for performance, at the expense of reliability. I have seen in the past any thread that asks for the opinion of "TDI gurus" attracts certain people which I admit are knowledgeable and have experience with Vanagon TDI conversions but often on forums people will argue their point to justify their choices. I do not have a TDI in my Vanagon and do not feel the need to expound on how much TDI experience I have. I am sorry if my opinion made you feel insecure . One final Caveat to the OP, if you decide on a VNT be careful where you purchase it. Quite a few people have bought hybrid vnt's that were not balanced properly that self destructed, some within 30 miles of installation. There was a 40 page thread of people coming forward on the TDI club who had kept quiet about it until one frustrated person decided to post about the vendor and his supplier. If you do decide on a VNT I would recommend a factory new stock unit.
*edit* I doubt I would stick my finger on a hot turbo to try and actuate the vanes Smile The minivac verifies that the actuator is functioning, you can also gauge at what point the vanes move and if they are now actuating properly at an appropriate level of vacuum. Also you can assure that the actuation is consistent. It is obviously the appropriate tool if you are going into limp mode without an N75 error.
jackbombay
PostPosted: Tue Feb 10, 2015 10:49 pm    Post subject: Reply with quote
jstar89crx wrote:
Greebly
I have not experienced any of the VNT issues nor have I heard of any of my friends with VNT TDI cars or Vanagons experiencing any problems. How many miles are on the affected turbos? [/b]
If you search around on TDIclub you can find instances of coked turbos where the vanes don't move freely as they should, this is supposedly caused by driving the car extremely gently which results in the vanes not moving significantly during normal use, carbon builds up and then blocks the vanes from moving. If the vanes move regularly they can easily wipe away small amounts of carbon.
You would really have to drive a car exceedingly gently for this to happen.
As for hydrolocking engines, the turbine shaft can break and motor oil will then get pumped into the intake, go through the intercooler and into the engine where it will burn and cause a "runaway" and or hydrolock the engine. This is also exceedingly rare and I've only ever read of it happening with very highly modded TDIs.
Samba ad here.
jstar89crx
jstar89crx is offline
PostPosted: Tue Feb 10, 2015 10:27 pm    Post subject: Reply with quote
On the ALHs you can just reach down behind the intake manifold and move the actuator with your finger too, I'm not familiar with the PDs or CRs though.
Same on the PD, or at least same as it is positioned at 15 degrees in my van.
Greebly
86 Syncro, weekender carat interior, the rest is bone stock for now
SOLD:91 Westy, BEW TDI with VNT17 Turbo, water cooled intercooler, Malone Tune, taller 3rd and 4th.
jackbombay
PostPosted: Tue Feb 10, 2015 10:20 pm    Post subject: Reply with quote
greebly wrote:
the surge line on the compressor map for the VNT is such that it is very easy to operate in a surge condition especially at altitude
I've plotted plenty of points on plenty of compressor maps over the years, and the only reason a VNT gets close to the surge line more easily than a wastegate turbo is because a VNT is so much better at making boost. If a turbo that makes lots of boost at any RPM is wrong I don't want to be right.
Samba ad here.
jackbombay
PostPosted: Tue Feb 10, 2015 10:10 pm    Post subject: Reply with quote
greebly wrote:
I have seen vanes coked on at least 10 TDIs .
Were any of those TDIs installed in a Vanagons?
I have worked on many ALH TDIs over the years and none of them have ever had turbo coking issues, I am not saying that it doesn't happen, but it is absolutely not a regular occurrence.
greebly wrote:
Used a minivac to exercise the vanes
greebly wrote:
The situation I described at 3000 ft actually occurred.
I never meant to infer that it didn't occur, I have also read of that happening, but its not common
greebly wrote:
I have gotten reports from more than one of hydrolocked TDIs with toasted motors.
And there are currently two threads on the Samba about Subaru engines blowing up in Vanagons, guess nobody should run those either?
Samba ad here.
luVWagn
luVWagn is offline
PostPosted: Tue Feb 10, 2015 9:55 pm    Post subject: Reply with quote
tjet wrote:
greebly wrote:
.... As far as manifolds clogging up, it has nothing to do with the turbo and I have never seen a clogged manifold grenade an engine, they simply lose a lot of power.
What causes the manifold clogging up?
http://www.greasecar.com/article/keep-your-act-clean-importance-intake-and-egr-cleaning-your-tdi
'91 Double Door Transporter
tjet
tjet is offline
PostPosted: Tue Feb 10, 2015 9:03 pm    Post subject: Reply with quote
big swifty
Location: Formally in Republic of VT; now in Hollywood, FL
big swifty is offline
PostPosted: Tue Feb 10, 2015 6:25 pm    Post subject: Reply with quote
My VNT17 was long in the tooth. Replaced it with an S7 from Kerma and I think it outperforms the VNT17 when it was new. I have other mods as well (see sig).
Evan
1987 Vanagon Syncro // Westfalia pop-top graft // Factory new ALH. 11mm IP. AFN 110 RC 2,3,4 // S7 turbo// Titan P502's
2013 Golf 4d TDI. Deleted. Tunezilla Stage2.
1991 Jetta coupe TD. Giles Superpump. SOLD
greebly
greebly is offline
PostPosted: Tue Feb 10, 2015 5:18 pm    Post subject: Reply with quote
I stated that the wastegated turbo is more reliable. I also stated that VNT turbo vanes can coke up and stick and that the surge line on the compressor map for the VNT is such that it is very easy to operate in a surge condition especially at altitude, be it from a defective tune, coked up vanes or a barometric sensor that fails to transition properly within the ecu. I won't argue the point further with anecdotes about what elevation you drive at regularly. Of course there are plenty of VNT equipped TDIs that operate at all sorts of condition without problems. As far as manifolds clogging up, it has nothing to do with the turbo and I have never seen a clogged manifold grenade an engine, they simply lose a lot of power.
hans j
hans j is offline
PostPosted: Tue Feb 10, 2015 4:45 pm    Post subject: Reply with quote
My TDI has been to 10,800 feet and survived just fine.
I've seen very few coked turbos, mostly intake manifolds and seizing wastegate actuators or holes in the diaphragms. I've seen several VNT turbos just plain blown up too. But realistically, very few issues. I've been working on them for about 14 years now at 4500 feet above sea level, and what you are describing isn't very common.
1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181
greebly
greebly is offline
PostPosted: Tue Feb 10, 2015 4:37 pm    Post subject: Reply with quote
Jack you have outside experience other than yourself?
I have seen vanes coked on at least 10 TDIs . Used a minivac to exercise the vanes to keep them from throwing codes and going into limp mode for awhile. The situation I described at 3000 ft actually occurred. I have gotten reports from more than one of hydrolocked TDIs with toasted motors. Quite a few that were transitioning from lower elevations to higher elevations. Surprisingly I have never heard of a 98 or older (wastegated turbo) TDI hydrolocking. Generally the turbos just plain wear out. It's hard to put a properly sized wastegated turbo into the surge line on the compressor map.
jackbombay
PostPosted: Tue Feb 10, 2015 4:23 pm    Post subject: Reply with quote
hans j wrote:
Yup. Drilled in the A of Garrett in the manifold. It seems like it's mostly heavy use when it's been lower than a straight pipe. Cruising it's normally 850*F at 64ish mph and fluctuates around there based on hills and wind.
Thats right about where mine was.
hans j wrote:
For me, the stock torque works great. I don't have to be in the left lane going up hills, but I'm still passing a few cars and all big rigs.
Yep, a TDI (stock) powered Vanagon is not fast, but its not slow either, a nice driveable vehicle IMO.
Samba ad here.
Page: 1, 2, 3  Next
