gear shift rod
KGCoupe
KGCoupe is offline
PostPosted: Sun May 03, 2015 6:38 am    Post subject: Reply with quote
If your shift rod is bent and leans to one side more than the other, perhaps you should try "shifting" with your other hand for a while.
Wink
paul_round
paul_round is offline
PostPosted: Sun May 03, 2015 3:05 am    Post subject: Reply with quote
Cheers John, I did skip through them ,but after reading the second one thoroughly, find my answer on page 3 Very Happy
John Moxon Premium Member
John Moxon is offline
PostPosted: Sun May 03, 2015 2:58 am    Post subject: Reply with quote
paul_round wrote:
Just about to fit the new shift rod bushing, however it is a loose fit between the tow rubber pads, is this normal? shouldn't it be snug?
If so, can I pack it out with something?
There are 2 comprehensive tutorials in the "How To" sticky Paul:
http://www.thesamba.com/vw/forum/viewtopic.php?t=157519
http://www.thesamba.com/vw/forum/viewtopic.php?t=436432
John.
paul_round
PostPosted: Sun May 03, 2015 2:47 am    Post subject: Reply with quote
paul_round
PostPosted: Sat May 02, 2015 12:41 pm    Post subject: Reply with quote
Finally! got it in.
Found these inside the tunnel:
Proper pedal rubbers!
paul_round
PostPosted: Sat May 02, 2015 12:20 pm    Post subject: Reply with quote
Actually, it does seem to be bent to a pattern, so I guess it's ok, just can't get the bugger back in!
Discovered I have an adjustable front beam and the adjuster is in the damned way!
-Zodiac-
-Zodiac- is offline
PostPosted: Sat May 02, 2015 12:02 pm    Post subject: Reply with quote
mine was bent, but it wasn't that bent.
1973 karmann ghia - current, not the last VW.
1947 Chevy stylemaster - gone, but not forgotten.
1995 Ford F-150 - gone, hatred for it lives.
jdoug
jdoug is offline
PostPosted: Sat May 02, 2015 11:55 am    Post subject: Reply with quote
Supposed to be. Clean it up good and grease it good before reinstalling.
paul_round
PostPosted: Sat May 02, 2015 11:16 am    Post subject: gear shift rod Reply with quote
I'm trying to sort out a sloppy gear change, so decided to change the bush and the coupling, however, when I pulled out the shift rod, it was bent:
Is this right?
I would have thought it was meant to be straight.
