towing with a bus
Red Fau Veh
Red Fau Veh is offline
PostPosted: Fri May 22, 2015 10:02 am    Post subject: Reply with quote
You went too big but trailers are popular so sell it and get a Heilite or simular.
1971 Deluxe Sunroof Bay 1905 stroker, dual idf40's, 74mm Scat forged crank, engle 110 cam. CB 044 heads, AutoCraft rockers, chromoly push rods
1973 Orange transporter stock type 4 with dual 40 Dellortos and Empi single quiet pack
1969 Adventurewagen blue whale Gene Berg 1776 built by Dave Kawell dual 36 DRLA's, Vintage Speed exhaust, Bosch 019 screamer
1961 Swivel Seat camper, L345 grey
Touch Nicks Thing wrote:
Swivel Seat panels are for people with no friends Crying or Very sad
cww
cww is offline
PostPosted: Fri May 22, 2015 9:50 am    Post subject: Re: Towing Reply with quote
Road apple wrote:
I pulled a 16 footer with my 62 truck with (1600 dual) last year from Ohio to Oklahoma. Had too much tongue weight at first (910lb) so moved most of the junk To the back of the trailer. Couldn't get out of the driveway at first without the front end flying off the ground.
Wired 12 cinder blocks to the hurst bumper and got on my way.
Steering still pretty squirrelly but made it in just under 19 days.
You should be fine with the smaller trailer. Laughing
This post gives me hope. Anybody wanna by a 65 arrow travel trailer?
Harleyelf
Harleyelf is offline
PostPosted: Fri May 22, 2015 9:47 am    Post subject: Reply with quote
I can just imagine seeing a row of cinder blocks in my rear view mirror!
Towing something which approaches the weight of the towing vehicle is dangerous; on a curve it can push the rear wheels of the front vehicle in a straight line and jack-knife you. Big rigs do it, but they have trailer brakes.
g3bill
g3bill is offline
PostPosted: Fri May 22, 2015 8:41 am    Post subject: Re: Towing Reply with quote
Cinder blocks, LOLOLOL Smile Talk about unsafe at any speed Laughing
Scary part is if trailer is too heavy and ya don't see a dip in the road at night you could bend or break hitch or frame i'd think.
I have Dial-Up an a hole in my pocket:)......Where are the 3 Stooges when we need them:)
'67 Camper PT westfail w/tent, hammock, jump seat. uping the motor to 1900 w/88bore/78crank.
& will be using carb 34 pict 3 ....Someday?
'82 Toyota 4x4 5sp PU lb, daily driver
Many Corvairs /& 4 rag tops
'63 Chevy 20 Truck w/4sp 292
Want, white plastic end pieces for dash grab handle
rebapuck
rebapuck is offline
PostPosted: Fri May 22, 2015 8:15 am    Post subject: Reply with quote
I had to get a bigger engine to pull my Puck up a hill.
So, no.
Judy
1966 Camper "Hannah"
1967 SingleCab "Khady"
iamdonquixote
iamdonquixote is offline
PostPosted: Fri May 22, 2015 7:54 am    Post subject: Re: Towing Reply with quote
holy cow!
Road apple
Road apple is offline
PostPosted: Fri May 22, 2015 6:08 am    Post subject: Towing Reply with quote
g3bill
g3bill is offline
PostPosted: Fri May 22, 2015 1:22 am    Post subject: Reply with quote
If you look here at bottom of 1st page you can see a pu bus towing a bug and another bus, not likely going up or down a hill though...
I read some posts where they say 100lbs max on the tongue and no more than 1000lbs on the trailer?
http://www.thesamba.com/vw/forum/viewtopic.php?t=299871&postdays=0&postorder=asc&start=0
No way i'd tow this boat with a vw van, weight is about 1200 with motor , dont know what the trailer weighs? 600#?
Admin note: non-vw pictures are deleted from the gallery
xavi_242
xavi_242 is offline
PostPosted: Fri May 22, 2015 12:54 am    Post subject: Reply with quote
it doubles the weight of my puck. My vote for: NO
1967 Split SO-42 Dormobile
g3bill
g3bill is offline
PostPosted: Fri May 22, 2015 12:45 am    Post subject: Reply with quote
I agree with you guys. Tongue weight around 60-80lbs would be better and no reduction gears is ,,,,, U want a show bus and be able to use it, not likely. U'd be lucky to get up a hill in 1st gear, maybe 2nd. With my '82 Toyota 5sp. PU I towed a 14 foot lido, very small light sail boat and a 8 foot sabot, another sail boat with a small boat trailer up the grape-vine and was a pain, usually in 3rd gear and 2nd, was ok on the flats.
Theres a gal that used to tow her 15-16 foot runabot boat with her VW van but stopped cause she didn't have the power to get up the hills, main reason think she said wasn't safe really, dont think she had trailer brakes. You can tow anything if you want. I towed a 25 foot cruiser with twin inboard merc's around the block once with my PU but was in low range 1st gear maybe 1 mile per hour Smile
mandraks
mandraks is offline
PostPosted: Thu May 21, 2015 8:32 pm    Post subject: Reply with quote
in germany tongue weight is usually around 100 pounds or less. More could be a problem.
On the flat it might be okay to pull it, my brother used to tow a small eriba trailer, one size up from the puck.
this style tows well, because they are narrow, not taller than the bus, they have brakes, and most importantly they are light weight
http://www.eriba.com/en/models/eriba/eriba-touring/layouts.html&singleview=43#.VV6hkne3eRs
regards
Uli
customcityjim
customcityjim is offline
PostPosted: Thu May 21, 2015 6:09 pm    Post subject: Reply with quote
Not safely, and your motor and trans will take a beating. Too much weight to pull.
cww
cww is offline
PostPosted: Thu May 21, 2015 5:58 pm    Post subject: towing with a bus Reply with quote
Just bought a 1965 arrow travel trailer. Weighs 1840 lbs, with a tongue weight of 248 lbs. Would a lowered bus with 1776 & bug tranny be able to pull this? I plan on adding trailer brakes.
