Raise the location of the front, inside seat belt anchor
singletrackrod
singletrackrod is offline
PostPosted: Fri Jun 05, 2015 1:45 pm    Post subject: Reply with quote
Vanis - I had thought of that; a section of flat bar and a bookbinders bolt, but the GW cable tether offers a option that places the receiver a bit closer to the seat. This is crucial in this case as the space available between the new fridge and the new seats is limited.
Merian - Of course you are right regarding the ultimate safety factor requiring significant design and testing, however since my next upgrade is a pair of Corbeau racing seats the fine points of exact placement sort of go out the window as the vectors and level points all will change.
Ella '89 Full Camper - bit by bit I'm importing the pieces from my wrecked '87
Louise '87 Full Camper - bought her new - zero hours 2.5L subie conversion. She had more add-ons and mods than I could ever count. (lost in an accident 10/25/2020)
'08 Stage 2 STI (sold)
'04 Forester XT
'00 4Runner Limited (sold)
Merian
Merian is offline
PostPosted: Fri Jun 05, 2015 1:28 pm    Post subject: Reply with quote
I assume those are copies of a VW item(?)
If so, they have gone thru a safety testing program.
While a competent welder can move the mount anywhere you want, only a group of engineers and large testing program can ensure that the relocated mount does not put crippling loads on your spine in case of an accident.
vanis13
vanis13 is offline
PostPosted: Fri Jun 05, 2015 1:27 pm    Post subject: Reply with quote
Seems like there is some buckle incompatibility as well with those replacement buckles.
How about a no-welding-necessary / low $ solution? - A section of 1/8" thick flat bar with a hole on each end and a bolt and make your own extension?
singletrackrod
PostPosted: Fri Jun 05, 2015 1:00 pm    Post subject: Thanks for all the great input Reply with quote
I appreciate everyone's input, apparently in my case, the best solution is going to be a pair of these: http://www.gowesty.com/ec_view_details.php?id=23412&category_id=&category_parent_id=
'04 Forester XT
GreenMachineVW
GreenMachineVW is offline
PostPosted: Thu Jun 04, 2015 1:32 pm    Post subject: Reply with quote
I was thinking like these:
kamzcab86
kamzcab86 is offline
PostPosted: Thu Jun 04, 2015 12:54 pm    Post subject: Re: Raise the location of the front, inside seat belt anchor Reply with quote
singletrackrod wrote:
...or lengthen the metal strap that holds the buckle.
That holds the buckle, or that holds the receiver? Longer receiver is readily available: http://www.van-cafe.com/home/van/page_1868_1346/front-seat-belt-receiver-for-non-swivel-seats.html .
~Kamz Anxious
2016 Golf GTI S
GreenMachineVW
PostPosted: Thu Jun 04, 2015 12:47 pm    Post subject: Reply with quote
I am fairly sure the Westfalia uses a shorter seat belt metal strap to allow the seat to swivel. Check out a non-Westfalia.
Terry Kay
Banned
Terry Kay is offline
PostPosted: Thu Jun 04, 2015 12:37 pm    Post subject: Reply with quote
As long as you have a welder, the fabricating skills to use it, you can move the mount anywhere you want.
T.K.
singletrackrod
PostPosted: Thu Jun 04, 2015 12:30 pm    Post subject: Raise the location of the front, inside seat belt anchor Reply with quote
I am plan on installing a Dometic CF-025DC Refrigerator between the front seats of my '87 Westy. In order to do this properly I would like to raise the inside anchor bolt location or lengthen the metal strap that holds the buckle. Does anyone have either experience with this modification or advice as to how to best accomplish it.
'04 Forester XT
