scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2977 Location: Thornton, CO
Posted: Sat Apr 08, 2017 8:08 am Post subject: Re: Front beam inspection plate bolt size? |
Thanks! I'm gonna go with whatever threads in properly.  |
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11431 Location: Oregon
Posted: Sat Apr 08, 2017 5:30 am Post subject: Re: Front beam inspection plate bolt size? |
Go with the pan head screw. Rounded top with short straight sides.
_________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Posted: Fri Apr 07, 2017 4:21 pm Post subject: Re: Front beam inspection plate bolt size? |
Is that what is known in the building trade as a 'zippy?' If so, I have a million of them.
I also have buckets of various sized cabinet hinge screws. |
Posted: Fri Apr 07, 2017 3:49 pm Post subject: Re: Front beam inspection plate bolt size? |
Scotty,
The inspection plate is held in place by a IDK, 2.5-3mm sheet metal screw. Not a 6mm bolt. The screw is about 10-12mm long.
If you need a pic I can take one for ya.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
Posted: Fri Apr 07, 2017 3:13 pm Post subject: Re: Front beam inspection plate bolt size? |
| Same bolt (6mm) for the inspection plate under the rear seat? Or is it the same as the what I think is a smaller bolt as on the steering box inspection cover plate in the front trunk? |
Northof49 Samba Member
Joined: July 22, 2013 Posts: 1759 Location: Winnipeg, Manitoba, Canada
Posted: Wed Jun 24, 2015 8:46 am Post subject: |
For mounting the shocks, I am simply using Grade 8 SAE hardware. Same with the axle to swingarm fasteners. They are just more readily available, and work fine. _________________ 1958 Karmann Ghia owner |
Jon's62 Samba Member
Posted: Wed Jun 24, 2015 8:12 am Post subject: |
| Cusser wrote: |
| You mean you drive a 50 year old VW and you don't have any spare metric hardware around ???? |
Point well taken! I have been making a habit of replacing and keeping spare bits on hand; This one had me stumped as I could not remember the size. As a rule though if I need 2 bolts I buy 4 or 6. Except those shock mount bolts at $22.00 a piece! I actually have never driven it....yet. |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33363 Location: Hot Arizona
Posted: Wed Jun 24, 2015 5:50 am Post subject: |
| That does help, thank you! If that's the case I should be able to get a nice pair of stainless hex bolts that fit. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7801 Location: Big Wonderful WYO 82401
Posted: Wed Jun 24, 2015 5:31 am Post subject: |
nothing special, just 6 mm _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
| tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
| sb001 wrote: |
maybe he just snapped cause his car sucked  |
Posted: Wed Jun 24, 2015 5:26 am Post subject: Front beam inspection plate bolt size? |
I seem to have misplaced my bolts! I am referring to the plate that sits behind the front beam. Are these a special size or could one find them at a nut and bolt supply? I checked the big blue factory manual but couldn't find any details. Any help would be appreciated,
Jon |
