kreemoweet Samba Member
Joined: March 13, 2008 Posts: 4141 Location: Seattle, WA
Posted: Wed Dec 09, 2015 12:16 pm Post subject: Re: Pict 34 solex jets in a Pict 34 Bocar? |
Bocar carbs often have very raggedy machining, with swarf all over the place. A jet could easily have been
partially plugged, creating leanness. _________________ '67 bug: seized by the authorities
eddie.would.go Samba Member
Joined: September 02, 2005 Posts: 96 Location: in the garage
Posted: Wed Dec 09, 2015 8:38 am Post subject: Re: Pict 34 solex jets in a Pict 34 Bocar? |
| I ended up swapping the jets and the bus ran alot better and not as hot. The tail pipe before was so clean you would have thought it had a catalytic converter. The exhaust was crazy hot too |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4779 Location: Arizona Highways
Posted: Thu Aug 27, 2015 7:05 am Post subject: |
the jets will fit and work.
what makes you think it runs lean? _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Wed Aug 26, 2015 9:25 pm Post subject: Pict 34 solex jets in a Pict 34 Bocar? |
I am having an issue with my 1600 DP in my 71 running on the lean side. When I try to richen it up it doesnt seem to run as good. I have read online that the Bocar 34's can be jetted on the lean side. I have an old parts Solex 34 and was wondering if I can steal the jets from it and run them in the Bocar? Will the fit/work?
The throttle shaft is tight in the Bocar carb as well |
