Distributor is stuck
05gh
05gh is offline
PostPosted: Tue Nov 10, 2015 2:03 am    Post subject: Reply with quote
Thanks for the advice I got this hamer out off mine cave.
I sprayed WD-40 and let is sit for one night, and it came loose, thanks.
Dana Champion
Dana Champion is offline
PostPosted: Mon Nov 09, 2015 11:16 pm    Post subject: Reply with quote
I've had pretty good success with one of these.
Laughing
Tom Powell
Tom Powell is offline
PostPosted: Mon Nov 09, 2015 9:18 pm    Post subject: Reply with quote
Or large channel lock pliers from Harbor Freight
http://www.harborfreight.com/16-in-professional-groove-joint-pliers-60413.html#reviews
or FLAPS
Aloha
tp
Tcash
Tcash is offline
PostPosted: Mon Nov 09, 2015 9:00 pm    Post subject: Reply with quote
When all else fails
Just kidding
Tcash
60's Burnout
60's Burnout is offline
PostPosted: Mon Nov 09, 2015 8:59 pm    Post subject: Reply with quote
A tangential strike with a big f*cking hammer usually works.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Mon Nov 09, 2015 7:23 pm    Post subject: Reply with quote
Tom Powell wrote:
Glenn wrote:
crownline wrote:
See if you can use a screwdriver in-between the bolt to gently pry apart clamp.
You'll bend the clamp.
Get a strap wrench.
That tool was useless for holding a Vanagon water pump pulley to remove the bolts from the pulley. It took a real strap wrench from NAPA for that job.
http://www.napaonline.com/Catalog/CatalogItemDetai...0210903481
The pulley strap wrench is expensive and the one pictured by Glenn may be adequate for the distributor.
Aloha
tp
The picture was of illustration, i wasn't recommending that specific wrench.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Wildthings
Wildthings is offline
Spray it up as mentioned. If the engine has been clean with no oil film for a long time and experienced some corrosion because of this, the distributor can seize very tightly into the case. You can made a wooded punch with which to apply force the the "bilge" of the distributor and maybe jar the dizzy body a bit to break the corrosion loose. Very light sideways taps against the vacuum can may help as well, but don't get carried away here, do use wood between your hammer and the can and go easy.
Tom Powell
PostPosted: Mon Nov 09, 2015 7:13 pm    Post subject: Reply with quote
Get a strap wrench.
Aloha
tp
Mr. 010
Glenn is offline
PostPosted: Mon Nov 09, 2015 6:51 pm    Post subject: Reply with quote
Get a strap wrench.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
Tom Powell
PostPosted: Mon Nov 09, 2015 6:29 pm    Post subject: Reply with quote
Tcash wrote:
Spray wd-40 under the clamp, so it wicks down the distributor shaft. On that shaft is a rubber seal that dries out and gets stuck.
Good luck
Tcash
Some of the replacement distributor shaft o-rings are a bit oversize from OG and require some muscle to get the shaft in the hole. That might be a contributing factor. Loosening the nut and prying the clamp wider will probably solve the problem. Don't take the nut off and lose the special screw.
Probably time for a new fan belt. Buy two and keep a spare.
Aloha
tp
Tcash
Tcash is offline
PostPosted: Mon Nov 09, 2015 4:51 pm    Post subject: Reply with quote
Good luck
Tcash
crownline
crownline is offline
PostPosted: Mon Nov 09, 2015 4:27 pm    Post subject: Reply with quote
1972 Bus 1700 cc Single Carb. But not a progressive.
Barelymuvin
Wish I still had the ones I got rid of.
"It"s got some dings and dents and neither of us is going to SEMA."(Update, I went to SEMA in 2019 but the Bus stayed home)
[url=http://www.vw-mplate.com/mplate-8446.png]Click to view image[/URL]
05gh
05gh is offline
PostPosted: Mon Nov 09, 2015 3:27 pm    Post subject: Distributor is stuck Reply with quote
I have loosen the bolt that holds the distibutor in place in order to set timing but it won't turn.
Need advice how to solve this problem.
