ente_kaefer Samba Member
Joined: August 22, 2013 Posts: 242 Location: St Louis, MO
Posted: Wed Nov 18, 2015 8:27 pm Post subject: Re: Correct Air Cleaner set-up |
citroen wrote: |
here is a 73 thing engine on the last Thing Ron and I just finished you will this engine is about the most original done you will find
Wow, all I can say is . . . wow . . . gorgeous!
A previous owner added a PICT 30 carb, Bosch 009 distributor, as well a 'Flamethrower' points and coil to my car, so my 1973 Thing will not be so 'nice' !
Seeing that the present set up in my car is working, I do not want to fix something that is working . . . |
Zylinderkopf Samba Member
Joined: September 09, 2012 Posts: 687 Location: SE Oklahoma
Posted: Wed Nov 18, 2015 4:13 pm Post subject: Re: Correct Air Cleaner set-up |
nice job on that '73 Dennis! You even have the green hose! _________________ 1963 Beetle
1966 Beetle 1300
1970 Karmann Ghia Coupe
1971 Super Beetle
1974 Thing
"A lot of people never use their initiative because no one told them to." |
citroen Samba Member
Joined: February 28, 2010 Posts: 1578 Location: louisville ky
Posted: Tue Nov 17, 2015 2:42 pm Post subject: Re: Correct Air Cleaner set-up |
here is the 73 thing engine on the last Thing Ron and I just finished you will find this engine is about the most original done you will find.
Posted: Tue Nov 17, 2015 12:12 pm Post subject: Re: Correct Air Cleaner set-up (vacuum hoses) |
Ron Domeck wrote: |
The long hose connects to the port on the left side of your intake that is plugged on yours. Were that hose is connected to now on the carb would have a hose to the back of the dist. Looks like the wrong Dist. in yours. Check out the engine pics at http://kubeltreffen181.com |
Thanks Ron...so Things originally came with dual vacuum advance distributors? I have a Mexican Bosch SVDA on it now. So what I think I'll do is keep the vacuum hose from the distributor where it is now (port on the left side of the carb). I will take the longer hose from the air cleaner elbow and connect it to the port on the intake manifold as you suggest and then plug the port on the back of the carb. _________________ 1963 Beetle
1966 Beetle 1300
1971 Super Beetle
1974 Thing
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Tue Nov 17, 2015 11:11 am Post subject: Re: Correct Air Cleaner set-up |
Posted: Tue Nov 17, 2015 8:42 am Post subject: Correct Air Cleaner set-up |
There are two hoses that start from the elbow, one goes to the cleaner and one to a port on the carb. I looked at a few pictures in the gallery and saw the hoses connected in a number of different ways. Which way is correct?
Thanks
1966 Beetle 1300
1971 Super Beetle
1974 Thing
