E-brake cable routing/adjusting
Splitless
Splitless is offline
PostPosted: Mon Jan 18, 2016 11:09 am    Post subject: Re: E-brake cable routing/adjusting Reply with quote
Still having trouble hooking my e-brake cables back up. These are OG cables that were fine before I pulled the trans. Are they really this tough to feed back up into the handle? Maybe I'm doing something wrong?
So.Cal Danny
So.Cal Danny is offline
PostPosted: Thu Nov 26, 2015 4:33 pm    Post subject: Re: E-brake cable routing/adjusting Reply with quote
This was the bottom of my 60 before I removed the cables
Splitless
PostPosted: Thu Nov 26, 2015 3:42 pm    Post subject: E-brake cable routing/adjusting Reply with quote
Does anybody have a good picture of the e-brake cable routing that is the same as a '61 bus?
I'm having a hard time getting both sides of the threaded cable ends up through the floor into the lever to mount/adjust them. It seems as the passenger side cable gets bound on the bottom of the heater tube preventing it to get pulled enough to come up to the hand brake lever. Not sure what I'm doing wrong.
