Intermittent loss of power during acceleration
pnw_ski_vanagoneer
pnw_ski_vanagoneer is offline
PostPosted: Fri Jun 10, 2016 8:12 am    Post subject: Re: Intermittent loss of power during acceleration Reply with quote
UPDATE - Just incase anyone was wondering - I solved the problem, had nothing to do with the gas tank, vent tanks, etc.
Turns out I screwed up distributor timing after incorrectly marking my distributor when removing it per some online instructions for replacing the water pump. Embarassed
Runs amazing now. Better than before even Cool wife said that van is like an addiction. Rolling Eyes
"If a problem can be solved there is no use worrying about it. If it can't be solved, worrying will do no good."
91 Tornado Red Carat
pnw_ski_vanagoneer
PostPosted: Tue Jun 07, 2016 5:34 pm    Post subject: Re: Intermittent loss of power during acceleration Reply with quote
A new symptom I noticed today was that it is much more pronounced when it's cold, even facing downhill, get significantly better when it's warm, but still there, i.e. it doesn't have the acceleration it used to have....
Is it worth draining the tank in preparation to drop and clean? Should I put back the old sensors? I'm at a bit of a loss here and I don't really have too much time to waste tracking this down..... Sad
pnw_ski_vanagoneer
PostPosted: Mon Jun 06, 2016 7:27 am    Post subject: Re: Intermittent loss of power during acceleration Reply with quote
I would be more inclined to believe that it's crud on the fuel tank outlet screen since I had the front end jacked up for about a week. But, is there anyway to actually check and verify without taking the tank off?
Also, if it is crud in the tank, is there a recommended way to clean it? or do just need a new gas tank?
andk5591
andk5591 is offline
PostPosted: Mon Jun 06, 2016 4:48 am    Post subject: Re: Intermittent loss of power during acceleration Reply with quote
or partially clogged tank vent system....
D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
There's more, but not keeping them...
insyncro
Banned
insyncro is offline
PostPosted: Sun Jun 05, 2016 7:51 pm    Post subject: Re: Intermittent loss of power during acceleration Reply with quote
Crud in your fuel tank blocking the outgoing spigot when going up hill.
pnw_ski_vanagoneer
PostPosted: Sun Jun 05, 2016 7:14 pm    Post subject: Intermittent loss of power during acceleration Reply with quote
Hi everyone, I just replaced my water pump, thermostat housing, sensors, thermostat, coolant, oil and filter. Before I go any further with transmission stuffs, I want to solve something:
It's having problems going up hills and accelerating on flat ground.... hills it used to have no problem going up. Basically, it feels like it is intermittently losing power, does this cold and hot, it is most noticeable on hills, but flat acceleration is similar. But does not happen as often when hot. I replaced the fuel filter today in an effort to fix this problem. Could it be the new temp II sensor was bad? bad connection with it? some weird cross sensor issue i'm missing? something else?
Idle's great, revs fine, cruises fine on flat ground, etc.
