Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS
jsturtlebuggy
jsturtlebuggy is offline
PostPosted: Mon Jun 13, 2016 9:14 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
Yes the early Bus rear drums (up to 1963) with small spline will work on a IRS rear brakes. The rain gutter on drum has the to be machined off and snout has to be machined shorter.
CIP1 sell cut down Bus drums to do this. There is a picture in their online catalog if you want to look.
My Dad and I did this back in the 1970s to replace stock brake drums that break from really wide wheels used in the sand.
Joseph
Fair Oaks/Orangevale, CA
Elrod Motorsports
Motion Tire Motorsports
Into Volkswagens since 1960
BL3Manx
BL3Manx is offline
PostPosted: Fri Jun 10, 2016 9:19 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
Used Thing drums will bolt on IRS brakes http://www.thesamba.com/vw/classifieds/search.php?...ton=Search
tpinthepack
tpinthepack is offline
PostPosted: Fri Jun 10, 2016 3:41 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
rear thing drums will go right on, but they are 1 inch wider yet the shoes are the same as the 68 bug.
TP in the Pack (I am a cyclist)
1968 Manx N.O.S. w/ Barrett Chassis
1960 Single Cab 1914 w/ 40 DLRA's
1990 Vanagon DOKA
1972 Super Beetle
1979 Super Beetle Convertible
2011 Porsche Cayenne
vwracerdave
vwracerdave is offline
PostPosted: Fri Jun 10, 2016 2:27 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
There is lots and lots of info available about converting 4 lug to wide 5 in the HBB Off-Road forums.
VOLKSWAGNUT
Fastest VW Belt Changer
Location: Flippin' a Belt........ .... Off-n-On ... NC USA
VOLKSWAGNUT is offline
PostPosted: Fri Jun 10, 2016 2:10 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
asps400 wrote:
Thanks for the link. A little expensive for me but a possibility.
Ha,, cheaper than more wheels and tires....
aka Ken {o\!/o}
Rebuilt to drive not decorate
Usually and often edited
asps400
asps400 is offline
PostPosted: Fri Jun 10, 2016 2:00 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
VOLKSWAGNUT
PostPosted: Fri Jun 10, 2016 12:34 pm    Post subject: Re: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
All depends.. are you planning to use a CV Joint (IRS ) Type 1(Beetle/Ghia) or Type 2 (Bus) CV Joint (IRS) suspension?
If its type for type.. maybe.. if its cross type.. probably not.
The Bus drums are much larger.
To use wide 5 Type 1 drums... with a Type 1 CV Joint (IRS) rear.. and keeping and using the 68 newer better rear brakes..
Conversion drums and done....
http://www2.cip1.com/ProductDetails.asp?ProductCode=C31-501-615-211AG
Search wide 5 IRS.. Its a popular conversion. ..
Always try searching for previous covered topics FIRST..
aka Ken {o\!/o}
asps400
asps400 is offline
PostPosted: Fri Jun 10, 2016 10:23 am    Post subject: Will Type 2 (early Bus wide 5) brakes and drums fit on 68 IRS Reply with quote
I have an early bus suspension and transmission I want to use on a buggy or trike. It sits too high because of the reduction gear boxes. I have found a 1968 IRS suspension but I want to use my wide 5 rims and tires because they were expensive. What do I have to do to put wide 5 drums on IRS suspension? Can I use my early bus drums?
