JasonBaker Samba Member
Joined: February 08, 2010 Posts: 1642 Location: Cleveland, TN
Posted: Tue Jul 19, 2016 11:34 am Post subject: Re: Scat universal linkage |
| It's been a long time since I installed the center-pull linkage. I think I had to remove a stud in the case and I think the large bolt that goes thru the engine case was too long and I cut it down to fit. |
videoguy009 Samba Member
Joined: March 31, 2008 Posts: 711 Location: Saint John N.B. Canada
Posted: Tue Jul 19, 2016 11:13 am Post subject: Re: Scat universal linkage |
Did you have any problem installing the large bolt thru the engine case?I looked carefully at mine and it looks like either the alt. stand may be too high or the alt. stand stud would prevent the bolt from going thru . _________________ 1971 Super Beetle |
Posted: Tue Jul 19, 2016 10:23 am Post subject: Re: Scat universal linkage |
Run the left arm on top of the linkage and the right side under the linkage arm. I had to use a 1/8 spacer, but that's because I am using a MST aluminum alternator stand.
Or you can run both underneath the linkage arm.
Not my pic, but you can see where the barrel nut goes for the throttle cable. Underneath it is the linkage arm I have been referering too.
This image has them backwards. Flip the adjustable linkage tube on the bottom for the right carb.
mark tucker Samba Member
Joined: April 08, 2009 Posts: 23945 Location: SHALIMAR ,FLORIDA
Posted: Mon Jul 18, 2016 5:37 pm Post subject: Re: Scat universal linkage |
| I didnt. |
Posted: Mon Jul 18, 2016 10:03 am Post subject: Re: Scat universal linkage |
Thanks alot.Didn't think you had to. _________________ 1971 Super Beetle |
cn63bug Samba Member
Joined: August 19, 2011 Posts: 114 Location: Mt. Juliet, TN
Posted: Mon Jul 18, 2016 9:50 am Post subject: Re: Scat universal linkage |
| You shouldn't have to. I installed mine while the stand was still on without any issues. |
Posted: Mon Jul 18, 2016 9:44 am Post subject: Scat universal linkage |
Do you have to remove or lift up the alternator stand to get the long bolt thru the engine case to support the linkage? _________________ 1971 Super Beetle |
