1972 bus ignition steering lock loose
chastings
chastings is offline
PostPosted: Sat Jul 30, 2016 3:30 pm    Post subject: Re: 1972 bus ignition steering lock loose Reply with quote
I should probably have said,
the part number is
211 (obscured by JB weld) (obscured by JB weld) 887 C
On the electrical side there's a
K 154
And to its right inside a circle is
KOLB
chastings
PostPosted: Sat Jul 30, 2016 3:26 pm    Post subject: 1972 bus ignition steering lock loose Reply with quote
The day after I bought my bus the ignition cylinder fell into my hand. I stuffed it back in and drove on. It happens a lot.
Recently I decided I should change the switch. It was only working 1/5 times. Of course, I got into it and found the switch is pretty new.
I also found that I can remove the cylinder by shaking the steering lock pretty hard.
Is there a way to tighten it up?
And I saw that the lock has a huge rectangular hole that runs on its bias. Its been JB welded shut.
Any idea why the hole and why the JB weld?
Thanks all,
C
