any tips for my engine rebuild. tks
britestart
britestart is offline
PostPosted: Fri Dec 02, 2016 1:50 pm    Post subject: Re: any tips for my engine rebuild. tks Reply with quote
again thank you. just want to be able to have a good driver. just in and cruise....ya
Cusser
Cusser is offline
PostPosted: Fri Dec 02, 2016 11:37 am    Post subject: Re: any tips for my engine rebuild. tks Reply with quote
I've used a stock cam in my 1835cc engine for 40 years now....I use a single Weber 40DCNF because in 1976 I changed from single port heads to the dual port heads, so I needed a new intake manifold anyway, and dual port end pieces were still costly back then.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Fri Dec 02, 2016 11:26 am    Post subject: Re: any tips for my engine rebuild. tks Reply with quote
Classic rookie pitfall, change cam. The stock cam will be best with your small engine. 2 barrel Weber is a waste of time when for a few dollars more you could have small duals, the duals give better performance and gas mileage too. A cheater cam or Engle 100 with small duals, small diameter single quiet pack would yield best results. There's a sticky at the performance forum that talks about proven combinations of engines of all sizes, read it.
Volks Wagen
Volks Wagen is offline
PostPosted: Fri Dec 02, 2016 10:46 am    Post subject: Re: any tips for my engine rebuild. tks Reply with quote
Measure everything and replace all the bearings. Check and maybe replace the oil pump. The cam depends on what u want to use the engine for - torque, revs etc. Then a lot of the rest of the decisions comes later. Heads are a very important selection. Look in the performance forum at the builds and you'll get some ideas.
1973 1303 with AB-motor - sporadic
reconstruction as time permits, 1986 ex-Bundeswehr Doka - on the road again.
I'm definitely, probably, the worlds greatest lover.
Aithníonn ciaróg ciaróg eile.
britestart
PostPosted: Fri Dec 02, 2016 7:42 am    Post subject: any tips for my engine rebuild. tks Reply with quote
74 1600. replacing jugs with 87mm. and a 2 barrel weber carb. stock heads.
should I up grade the cam. or not? since I have it apart I just wanted some input. tks
