EVfun  Samba Member
Posted: Fri Mar 03, 2017 11:44 am Post subject: Re: Speedo cable clip |
| glutamodo wrote: |
| Dr OnHolliday wrote: |
| ...or wrap some fine wire around it on the outside of the dust cap, ... |
I'm glad I'm not the only one who's done this. |
Me too.  _________________
| Wildthings wrote: |
| As a general rule, cheap parts are the most expensive parts you can buy. |
glutamodo  The Android
Joined: July 13, 2004 Posts: 26632 Location: Douglas, WY
KTPhil  Samba Member
Joined: April 06, 2006 Posts: 36316 Location: Conejo Valley, CA
Posted: Wed Mar 01, 2017 11:15 am Post subject: Re: Speedo cable clip |
| The cable sheath itself is usually held in place by the rubber grommet at the center of the steering knuckle on the inboard side. I've seen this absent on some cars, though, which would make the clip necessary. |
Bob Loblaw Samba Member
Joined: August 17, 2008 Posts: 865 Location: Vancouver Island, Canada
Posted: Wed Mar 01, 2017 10:08 am Post subject: Re: Speedo cable clip |
| Karzapart55 wrote: |
| What size is the speedo cable clip at the driver side dust cap? Thanks |
4mm _________________ sent from a phone using poor grammar and spelling |
gt1953 Samba Member
Joined: May 08, 2002 Posts: 13958 Location: White Mountains Arizona
Posted: Wed Mar 01, 2017 6:53 am Post subject: Re: Speedo cable clip |
Wrap fine wire is my cure, or a visit to ACE hardware or Wolfburg West or ?? _________________ Volkswagen: We tune what we drive.
72 type 1
72 Squareback
Cali_Army_Guy Samba Member
Joined: March 19, 2015 Posts: 2094 Location: Stockton, CA
Posted: Tue Feb 28, 2017 11:58 pm Post subject: Re: Speedo cable clip |
Or get really crazy like me and others have done and buy a $400 GPS speedometer and lose the entire cable setup completely  _________________ 2015 VW Passat Wolfsburg Edition
1966 VW Beetle - Sold |
Dr OnHolliday Samba Member
Joined: May 11, 2012 Posts: 1215 Location: was Escondido now San Berdoo
Posted: Tue Feb 28, 2017 11:57 pm Post subject: Re: Speedo cable clip |
...or wrap some fine wire around it on the outside of the dust cap, like mine has been for 15k miles now after losing that little turd... _________________ 1965 Type 1 sunroof Baja / about 70k miles on self-rebuilt '74 1600 and counting / SP heads and aftermarket valve keepers / non-doghouse shroud with external cooler and filter / 1.5 qt extended sump / Weber 32/36 DFAV progressive carb / 009 dist with Pertronix / 1.25 ratio rockers and ball adjusters / 1.5" stainless steel J-pipes and carbon steel baja exhaust
Last edited by Dr OnHolliday on Wed Mar 01, 2017 12:18 am; edited 1 time in total |
andk5591 Samba Member
Joined: August 29, 2005 Posts: 16813 Location: State College, PA
Posted: Tue Feb 28, 2017 7:27 pm Post subject: Re: Speedo cable clip |
| Cusser wrote: |
| Or you can drill a small hole and use a cotter pin to hold the cable in the dust cap. |
I do this a LOT _________________ D-Dubya Manx clone 1914. Ex wifes car.
Maxine 61 Cal-look bug - Ex-wifes car.
67rustavenger Samba Member
Joined: February 24, 2015 Posts: 11517 Location: Oregon
Posted: Tue Feb 28, 2017 7:11 pm Post subject: Re: Speedo cable clip |
Or not run the clip. Like I do! Never had an issue with the speedo cable slipping back out of the bearing cap. Been doing this for years.
Good Luck. _________________ I have learned over the years.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
2003 Astrovan? GFYS again, Xevin!
Don't let your bad ideas remain, ideas! |
Cusser Samba Member
Joined: October 02, 2006 Posts: 33442 Location: Hot Arizona
Digger89L Samba Member
Joined: May 16, 2013 Posts: 1130 Location: Western Canada (SK)
Karzapart55 Samba Member
Joined: May 26, 2004 Posts: 642 Location: Old Bridge NJ
Posted: Tue Feb 28, 2017 5:01 pm Post subject: Speedo cable clip |
What size is the speedo cable clip at the driver side dust cap? Thanks _________________ Central Jersey Volkswagen Socity |
