Mad monk Samba Member
Posted: Wed May 26, 2021 2:09 pm Post subject: Re: Westy Front Table Dimensions? |
| Thanks Mark 😎👍 |
MarkWard Samba Member
Joined: February 09, 2005 Posts: 19074 Location: Retired South Florida
Posted: Wed May 26, 2021 11:38 am Post subject: Re: Westy Front Table Dimensions? |
| Mad monk wrote: |
| I’m also in the process of making a front table, is the table the same thickness as the rear one? |
Yes same thickness. |
Posted: Wed May 26, 2021 11:37 am Post subject: Re: Westy Front Table Dimensions? |
gene l Samba Member
Joined: August 31, 2013 Posts: 136 Location: LOS OSOS,CA.
Posted: Mon Mar 13, 2017 8:06 am Post subject: Re: Westy Front Table Dimensions? |
| I put my front table mount on the back side of the door under the sink & stove, and use the door as my table. Saves carrying the top around. |
volks_womble Samba Member
Joined: December 23, 2016 Posts: 2 Location: West Sussex, UK
Posted: Mon Mar 13, 2017 3:30 am Post subject: Re: Westy Front Table Dimensions? |
Dan,
Thanks very much for taking the time to get the measurements
Being an '89 van, we have the later (shorter) wardrobe door, so the main table can stay for now, but an extra bit of surface up front is definitely required!
Thanks again
Mark |
yellowjacket Samba Member
Posted: Sun Mar 12, 2017 4:45 pm Post subject: Re: Westy Front Table Dimensions? |
Yes, the nominal dimensions of the front table is 400 mm x 600 mm.
Measurement b) 260 mm and c) 250 mm for the table leg mount.
Measurement d) 285 mm and h) 565 mm for the table leg.
Mine is the other style mount, probably same measurement.
Warm day sitting around on the patio, 92 degrees (F), so thought I'd take a measurement for you. I use another front table for then rear table position as it's a little easier to access wardrobe closet.
Have fun with your project.
Dan _________________ 86 Syncro Westy - Bostig RG11
71 Squareback |
Posted: Fri Mar 10, 2017 11:22 pm Post subject: Westy Front Table Dimensions? |
So, I had a look they the FAQ, and the dimensions thread, but so far haven't found the dims that I need...
I would like to like to recreate a westy front table to go into our California. I know they are available from a couple of sources, but they are relatively rare and expensive here in the U.K., plus I want to have a go anyway...
I want it to be as close to factory as possible, but I don't have one to work from as a pattern. I wonder if someone who has one could do a bit of measuring for me?
I need the following dimensions:
[*] Table top Length x Width (LxD) (I believe the table itself is nominally 600x400mm - presumably this is the size of the timber prior to putting the edging strip on?)
[*] Position of the mounting bracket underneath (a, b and c - the bracket looks to be on the centreline of the table?)
[*] The length of the horizontal and vertical sections of the leg (d and h)
Here's a picture I stole off t'internet and added some labels to refer to the required measurements:
Any help will be very much appreciated.
Thanks
Mark |
