Air Conditioning
duckyde
duckyde is offline
PostPosted: Thu Jun 29, 2017 3:56 pm    Post subject: Re: Air Conditioning Reply with quote
Yeah everything would have to be replaced but at least I can tell how things were routed to begin with. It also sounds like I have the split condenser system. I like the idea of the overhead system as I think it would be more efficient.
Hoody
Hoody is offline
PostPosted: Tue Jun 27, 2017 5:11 pm    Post subject: Re: Air Conditioning Reply with quote
Gilmore enterprises.
MaddMatt
MaddMatt is offline
PostPosted: Tue Jun 27, 2017 8:59 am    Post subject: Re: Air Conditioning Reply with quote
My 71 came with A/C and I took it all out. I have the ceiling unit, the hoses, the evap, and a few other parts. The only thing I'm missing is the compressor. I have no use for it, message me if you want to make a deal.
It will make it. Trust me.
Owned: 71 Superbeetle, 72 Superbeetle, 63 Baja (on 69 pan) 74 baja, 74 Karmann Ghia
Own: 71 Deluxe Bus
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Jun 26, 2017 7:50 pm    Post subject: Re: Air Conditioning Reply with quote
busdaddy wrote:
Sounds like it's better to start fresh in your case.
There's at least 3 different A/C systems from different manufacturers like DPD and VWP (Ccoool), some have the single large condensor, others have a split condensor with 1/2 across in front of the beam and 1/2 under the bus.
X2.....
your hoses are now junk and the receiver/drier needs to be replaced any time the system is open to atmosphere any longer than it takes to swap a component (like no more than 30 min) the desiccant bag in the drier is wasted when it's opened to atmosphere
you should really study up on automotive a/c....it's not cheap and you do need at least 3-500 in (cheap) specialty tools to diy the system. you are working with high pressure stuff that will ruin your life if you mess up.
68bahamahyellow did a nice install of the mid mount. it's a lot of work but when done properly it does pay off
gprudenciop wrote:
[email protected] wrote:
Jake Raby wrote:
Brian wrote:
busdaddy
busdaddy is offline
PostPosted: Mon Jun 26, 2017 7:37 pm    Post subject: Re: Air Conditioning Reply with quote
Слава Україні!
duckyde
duckyde is offline
PostPosted: Mon Jun 26, 2017 7:31 pm    Post subject: Re: Air Conditioning Reply with quote
I have the front to back hoses for the most part, some have been cut off. drier is in place, and mine has a front undermounted condenser but the brochures show a mid-mounted condenser and at some point mine was removed. Hoses are still there, is the only reason I knew it had it at all.
skills@eurocarsplus
Samba Peckerhead
PostPosted: Mon Jun 26, 2017 7:13 pm    Post subject: Re: Air Conditioning Reply with quote
by your list, you are missing everything.
you can buy this:
http://iceautoair.com/index-1VWBus.html
here is my install
https://www.thesamba.com/vw/forum/viewtopic.php?t=659687&highlight=subaru
it was a LOT of work...but I did it right when I relocated the fuse box. it ate a lot of time, but the results are worth it
Jake Raby wrote:
Brian wrote:
busdaddy
busdaddy is offline
PostPosted: Mon Jun 26, 2017 7:10 pm    Post subject: Re: Air Conditioning Reply with quote
Welcome,
Some owners are still running the original A/C, most have upgraded to a modern compressor though. Scroll down to near the bottom here: https://www.thesamba.com/vw/archives/manuals/heater_ac.php and have a look at some of the acessory brochures here: https://www.thesamba.com/vw/archives/lit/type2_2.php to identify the system you have and see the parts lists.
Слава Україні!
duckyde
duckyde is offline
PostPosted: Mon Jun 26, 2017 6:58 pm    Post subject: Air Conditioning Reply with quote
Hey, any of you guys have stock air conditioning for your bay window? I recently bought a '77 with factory air however some pieces are missing (under-dash evap, compressor, bracket, belt drive) and I'm trying to locate the missing parts but I'm having trouble finding pictures of exactly what I need. Also is it possible to install a over head a/c evaporator in a bus that had the dash mount? Has anyone tried? Can you run both? Any help (pictures) is appreciated!
