How to clean distributor
flat4olsen
flat4olsen is offline
PostPosted: Wed Oct 25, 2017 5:36 am    Post subject: Re: How to clean distributor Reply with quote
"water polishing" or "vandpolering" in danish. I am not familiar with the correct english term.
Zundfolge1432 Premium Member
Zundfolge1432 is offline
PostPosted: Wed Oct 25, 2017 4:18 am    Post subject: Re: How to clean distributor Reply with quote
Yes go big like this machine which uses a plastic media to clean light alloy parts. It will not erode or remove any factory coatings but does remove all dirt and stains. Does a beautiful job on carbs,fuel pumps,distributors, cylinder heads etc. runs about 35 psi and can be used as booth or walk in. Cleans faster than a cat can lick its ass. Very Happy
heimlich Premium Member
VWNOS.com
heimlich is online now
PostPosted: Tue Oct 24, 2017 10:26 pm    Post subject: Re: How to clean distributor Reply with quote
I sell a product you can use in combination with an ultrasonic cleaner. It will not oxidize your aluminum. Let me know if you are interested.
Glenn Premium Member
Mr. 010
Glenn is offline
PostPosted: Tue Oct 24, 2017 6:04 am    Post subject: Re: How to clean distributor Reply with quote
wcfvw69 wrote:
Get out the industrial sand blaster and let er rip! Go big or go home! Laughing
Yup... you can wash the sand out with gasoline. (j/k)
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Tue Oct 24, 2017 6:01 am    Post subject: Re: How to clean distributor Reply with quote
Tooth brushes? "Gentle chemicals"? Use a delicate touch!?!?! PPffffttttt...
The Samba member since 2004.
Mr. 010
Glenn is offline
PostPosted: Tue Oct 24, 2017 4:44 am    Post subject: Re: How to clean distributor Reply with quote
Ultrasonic cleaner and gentle chemicals.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
tasb
The Distributor Distributor
tasb is offline
PostPosted: Mon Oct 23, 2017 9:42 pm    Post subject: Re: How to clean distributor Reply with quote
Use a childs toothbrush to remove any grime from nooks and crannies in the distributor body.[/quote]
As above old toothbrushes work great. I do my deep cleaning of fully disassembled distributors with lemon juice in a hot pot with great results.
Roads Scholar
Member# 2059
Meiang
Meiang is offline
PostPosted: Mon Oct 23, 2017 5:08 pm    Post subject: Re: How to clean distributor Reply with quote
To give it a good clean you will need to remove the vacuum advance unit, condenser and the distributor cap clamps. The small screws holding these in place are often very tight and can be difficult to remove. You should use the right size screw driver which just fits in the screw head slot otherwise you risk damaging the slot. I often find using a 1/4"ratchet with a screw driver insert is the best way to undo the screws, again make sure that the screw driver insert is as big as possible so that the slot does not get damaged.
I like to retain the original factory finish to the distributor housings. If you use any abrasive cleaners or wire wheels you get that "someones just cleaned a worn out distributor" look.
My process of cleaning is:
1) Methylated Spirits to remove easily movable grime.
2) Orange Oil to remove more stuborn grime.
3) Brasso to remove the grime that the first two don't remove.
With the Brasso, just dab the fluid on the distributor body, don't rub or you will get a polished effect. Don't leave the Brasso on for more than a few seconds and gently remove using a wet cloth with a dabbing action.
wcfvw69
Samba Purist
wcfvw69 is offline
PostPosted: Mon Oct 23, 2017 5:06 pm    Post subject: Re: How to clean distributor Reply with quote
Make sure you check that DVDA vacuum canister with a hand vacuum pump and gauge first. Most used ones I see are blown on either the retard side or the advance side. It would be terrible to make the distributor all pretty and it not work due to the vacuum canister. Wink
As Tim mentioned, I'm sure it needs a deep service too if it's never been apart. Every one I disassemble that's never been apart since new are filthy. The old grease is hard and all the parts need to be re-greased and re oiled.
busdaddy
busdaddy is offline
PostPosted: Mon Oct 23, 2017 4:54 pm    Post subject: Re: How to clean distributor Reply with quote
I find those little stainless and brass toothbrushes that come in a 3 pack along with a plastic one from Harbor freight work very well on things like that, adding a little solvent or WD-40 seems to make it even shinier, there's no instant fix, it does require some elbow grease to look nice.
Слава Україні!
gt1953
gt1953 is offline
PostPosted: Mon Oct 23, 2017 4:44 pm    Post subject: Re: How to clean distributor Reply with quote
I have used the dremel tool little wire wheel. Then chrome polish.
72 type 1
72 Squareback
tasb
tasb is offline
PostPosted: Mon Oct 23, 2017 9:10 am    Post subject: Re: How to clean distributor Reply with quote
0000 steel wool and elbow grease. While you are there, a few drops of oil on the wick under the rotor and some grease on the points rubbing cam.
Roads Scholar
Member# 2059
Mr. 010
Glenn is offline
PostPosted: Mon Oct 23, 2017 9:04 am    Post subject: Re: How to clean distributor Reply with quote
Wire brushes, steel wool or other abrasives.
Personally, i'd leave it and not open a can of worms.
Glenn
Member #1009
#BlueSquare
עַם יִשְׂרָאֵל חַי
sshulk
sshulk is offline
PostPosted: Mon Oct 23, 2017 8:59 am    Post subject: How to clean distributor Reply with quote
Hey guys. Im curious how i can clean the exterior of my dvda distributor. Im putting a pertronix kit in it so i have it out of the car and figured i would clean it up. Any tips are appreciated.
Filthy Buggers NJ
73 Super German Looker
68 Panel Bus Dave Brown Racing Engines
62 Notchback
60 Mango Ragtop Camper Bug Project Thread
63 Ragtop Project
73 Auto Westfalia
2056 Type 4 Engine Build Thread
Filthy Buggers
