markswagen Samba Member
Joined: January 28, 2018 Posts: 1555 Location: san diego
Posted: Tue May 22, 2018 7:29 am Post subject: Re: 84 Vanagon stuck in gear |
Before you drop the transmission, take the linkage off first, I have seen them bind and stick giving the feeling of being stuck in gear.
With the linkage off, can you move through the gears, on the linkage on the side of the transmission, if no, now you need to drop the transmission. _________________ markswagen {mobile mechanic} san diego area all early VW's cared for.
619 201 0310 |
Trueblue84 Samba Member
Posted: Mon May 21, 2018 6:22 pm Post subject: Re: 84 Vanagon stuck in gear |
| Thanks for the quick replies everyone. Sounds like the jury is in agreement. It's been towed to my trusted VW shop for further inspection. Will update if it's some kind of curveball. |
dhaavers Samba Member
Joined: March 19, 2010 Posts: 8508 Location: NE MN (tinyurl.com/dhaaverslocation)
Posted: Mon May 21, 2018 12:59 pm Post subject: Re: 84 Vanagon stuck in gear |
^^^ Stop driving before you grenade the whole thing & still have a rebuild-able core...
- Dave _________________ 86 White Wolfsburg Westy Weekender
"The WonderVan"
Zeitgeist 13 Samba Member
Joined: March 05, 2009 Posts: 12175 Location: Port Manteau
Posted: Mon May 21, 2018 12:57 pm Post subject: Re: 84 Vanagon stuck in gear |
The trans needs to come out and be rebuilt or replaced. Sorry. _________________ Casey--
'89 Bluestar ALH
'01 Weekender --> full camper
NEAT, no ICE. |
Posted: Mon May 21, 2018 12:01 pm Post subject: Re: 84 Vanagon stuck in gear |
| borninabus wrote: |
it's actually the 3-4 slider hub. but yes, you are most likely right.
sorry  |
Any other tests I can do, or other advice? |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4774 Location: Arizona Highways
Posted: Mon May 21, 2018 11:56 am Post subject: Re: 84 Vanagon stuck in gear |
sorry  _________________ 88 Van WBX, A/T - 93 Multivan 5cyl 5M/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
Posted: Mon May 21, 2018 11:44 am Post subject: 84 Vanagon stuck in gear |
I was driving in 4th gear and went to downshift into 3rd and the shift level stuck. It will not unstick now.
We know the clutch works, as while the tranny is stuck in gear we can run the engine with the clutch depressed. Shift linkage seems fine. No obstructions in the front. When I pull the linkage from the shaft on the tranny I still cannot move the shaft with pliers.
Could this be the notorious disintegrating 4th gear synchro issue? Seems like the research would support this |
