HELP!!!!! Wont start
Dezrtracer32
Dezrtracer32 is offline
PostPosted: Sun Jun 17, 2018 10:20 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
She fired today! I charged the yellowtop and got it to fire 4 times. It wouldn't stay running without the throttle pressed. And now the car turns over very slow and wont start. So I'm thinking a fuel pump and q starter and I should be good. The car has plates that were registered in 94. So I'm sure sitting for that long and then starting wasn't very nice on it. Any other ideas of what could be the issue? Thanks in advance
ashman40
ashman40 is offline
PostPosted: Sat Jun 16, 2018 10:32 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Maybe it is time to start from scratch. Read Speedy Jim’s page on no start and run thru all the steps.
http://www.speedyjim.net/htm/eng_strt.htm
AshMan40
67rustavenger
67rustavenger is offline
PostPosted: Sat Jun 16, 2018 8:55 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Backfire?
Check your firing order. It should not do that if set correctly. 1-4-3-2.
Good Luck.
Buy Once, Cry Once!
GFY's Xevin and VW_Jimbo!
Dezrtracer32
PostPosted: Sat Jun 16, 2018 8:44 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Yes I adjusted the points on the lobe. And did the timing with a test light. I have gotten the car to backfire. But as soon as i got that the battery died... so hopefully tomorrow i can get it to kick on
Dezrtracer32
PostPosted: Sat Jun 16, 2018 12:29 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Just an update. I'm getting 28 ohms on coil. So I'm assuming it's a bad coil
VW_Jimbo Premium Member
VW_Jimbo is offline
PostPosted: Sat Jun 16, 2018 10:55 am    Post subject: Re: HELP!!!!! Wont start Reply with quote
I read that you adjusted the points. I am hoping you set them while the rubbing block was on a lobe! Because if you set them when it was not, you would never get spark! Just checking that you did it correctly.
Jimbo
TDCTDI wrote:
67rustavenger wrote:
ashman40
ashman40 is offline
PostPosted: Sat Jun 16, 2018 10:53 am    Post subject: Re: HELP!!!!! Wont start Reply with quote
Put your voltmeter on the ignition coil #15 (+) terminal and monitor the voltage WHILE you crank the engine. Often you will find 12v while the ignition is ON but the starter is not cranking. But when you turn the key to start the starter draws so much current off the battery that the voltage that makes it to the ignition coil drops below the minimum. So you can pass all tests you conduct while the engine is OFF, but the voltages tests will fail WHILE the engine is cranking.
Related to this you may find that the ignition switch has failed. The internal contacts work in the ON/RUN position but the ignition switch stops passing current to the ignition coil when the key is in the START position.
For '71-later Beetles you sometimes see the PO has mistakenly wired the black/yellow (#X) wire in place of the black (#15) wire. Unfortunately, the black/yellow wire does NOT provide 12v when the ignition switch is in the ON position so it is not suitable for use with the ignition coil.
AshMan40
David_nc_72std
David_nc_72std is offline
PostPosted: Sat Jun 16, 2018 6:02 am    Post subject: Re: HELP!!!!! Wont start Reply with quote
If possible, post a picture of the engine, someone may be able to spot an obvious problem.
Was the engine running previously, and then suddenly would not start, or have you never had it running? If it was running previously, did you do any work on the car, even if it seems unrelated to the engine.
Does the engine crank and never fire, or does it try to run and quit after a few seconds?
You stated that the engine was timed, how did you time it?
How did you check for spark?
Cusser posted a picture of the distributor/spark plug wiring earlier, don't follow that diagram blindly, not all distributors have the #1 terminal in the same position, and sometimes the distributor drive gear gets installed in the wrong position. You have to turn the crankshaft to TDC and verify you are on the compression stroke of the #1 cylinder to know for sure where the #1 spark plug wire goes.
There should be only one wire connected to the #1 terminal of the coil, the wire from the condenser on the distributor - if anything else is connected to that terminal it will keep the ignition from working (unless you have a tachometer, if so disconnect that until you get the engine running, just to eliminate it as a possibility).
A couple of things to check that rarely go wrong, some distributors have a short wire connecting the points plate inside the distributor to the distributor body, that can break and prevent the points from getting a good ground. Also, if you have had the battery disconnected, make sure you didn't reconnect it with the terminals reversed, the (-) terminal goes to the chassis ground. This is an easy mistake to make if you are borrowing a battery from another car, because some batteries are build with the terminals "reversed" and its easy to just connect it without paying attention to the polarity.
Dezrtracer32
PostPosted: Fri Jun 15, 2018 10:20 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
I will run that and see what happens. Thank you for the info everyone Updates will be posted for anyone interested
Tim Donahoe
Tim Donahoe is offline
PostPosted: Fri Jun 15, 2018 9:47 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
If you have no wire going from #15 side of the coil to the electromagnetic cut-off switch (the solenoid in the diagram above) at the carburetor, then your solenoid will not open, allowing fuel to your carburetor.
Install a wire with female connections from the #15 male connection at the coil to your solenoid on your carburetor.
While you’re at it, you might want to pigtail this wire to your automatic choke—as shown in the diagram.
Tim
Let's do the Time Warp again!
Richard O'Brien
Dezrtracer32
PostPosted: Fri Jun 15, 2018 9:20 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
So judging by that schematic I'm missing the wiring going to the carb and transmission switch and lights. Will that really cause it not to start?
Pruneman99
Pruneman99 is offline
PostPosted: Fri Jun 15, 2018 9:15 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Dezrtracer32 wrote:
Yes I set it to the .016 is that right?
That should be fine. Make sure the distributor is engaged in the gear as suggested above. You shouldn't be able to spin the rotor by hand.
You shouldn't need an external resistor unless you are using the wrong coil.
12v from the key should go to the + side of the coil, and the condenser should be plugged into the - side.
Cusser
Cusser is offline
PostPosted: Fri Jun 15, 2018 9:13 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
vwoldbug
vwoldbug is offline
PostPosted: Fri Jun 15, 2018 9:02 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Did you make sure the distributor is seated all the way and rotor is spinning .
Dezrtracer32
PostPosted: Fri Jun 15, 2018 8:58 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Pruneman99
PostPosted: Fri Jun 15, 2018 8:38 pm    Post subject: Re: HELP!!!!! Wont start Reply with quote
Did you set your point gap?
Dezrtracer32
PostPosted: Fri Jun 15, 2018 8:34 pm    Post subject: HELP!!!!! Wont start Reply with quote
I have a 69 with a 1600. I am getting fuel to the carb but not getting spark. I have replaced the coil,plugs,wires,cap,rotor,condenser and am getting 12v all the way from key to cool but the car wont fire. Does the coil need the external resistor to work right? The engine is timed and everything I can think of has been gaped/adjusted. Any input would be great! Thanks in advance
