Mellow Yellow 74 Samba Member
Joined: October 14, 2014 Posts: 1615 Location: Sydney, Australia
Posted: Tue Jul 31, 2018 11:47 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
You should check the procedure on how to charge the radius rod bushes first because you may need to remove the whole lower control arm (not sure on your early style radius rods) so it might be worth having new bushings for these as well.
Also check out getting a sway bar (aka anti roll bar) and associated parts as well. _________________ 1962 Karmann Ghia
1974 Deluxe Microbus
1985 Caravelle (Vanagon) |
Ettolitro Samba Member
Posted: Tue Jul 31, 2018 9:42 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
Show my silent...
thanks for the answers and thanks to all the members for the suggestions. I ordered all the silent blocks as soon as I get them up I'll let you know if I solve. |
shagginwagon83 Samba Member
Jake de Villiers Samba Member
Joined: October 24, 2007 Posts: 5938 Location: Tsawwassen, BC
Posted: Mon Jul 30, 2018 9:42 am Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
As Mellow Yellow said, if you're in Europe get in touch with Brickwerks, if North America, VanCafe.
Good luck! _________________ '84 Vanagon GL 1.9 WBX
@jakedevilliersmusic1
www.crescentbeachguitar.com
www.thebassspa.com |
MsTaboo  Samba Member
Joined: June 02, 2006 Posts: 4623 Location: East Kootenay, British Columbia
Posted: Mon Jul 30, 2018 8:13 am Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
Sorry. Should have pointed out the picture I posted is of a Syncro's radius rod end, so it looks a bit different than yours but same idea. _________________ Currently:
Resist Kleptocratic Oligarchy (and Idiocracy)! |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Mon Jul 30, 2018 4:51 am Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
This video _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
Posted: Mon Jul 30, 2018 12:36 am Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
It is the right had end of the radius rod in photo 1, the hole in the left hand end is where the drop link for the sway bar is meant to go. Photo 2 is the tie rod end. _________________ 1962 Karmann Ghia
Posted: Sun Jul 29, 2018 9:56 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
| levi wrote: |
The YouTube video labeled "Front brake noise 1" shows the squeak coinciding with the radius rod movement.
I wonder if the hole that the radius rod passes through has been damaged enough that the metal sleeve is rubbing, metal on metal.
It's not too unusual to see that hole double the original size. |
are you talking about this auction? thank you for your precious time
Photo 1 or photo 2 ?
1 :
2:
Thank!
[/img] |
Posted: Sun Jul 29, 2018 9:48 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
| levi wrote: |
This is the wear levi is describing, on this one it's just starting to wear through the inner sleeve but if left too long the rod will start eating the frame.
(the portion that's missing is steel not rubber)
And the worn out bushings/sleeves with Powerflex replacements in the rear. _________________ Currently:
levi Samba Member
Posted: Sun Jul 29, 2018 6:37 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
It's not too unusual to see that hole double the original size. _________________ One of these days I'm gonna settle down,
Posted: Sun Jul 29, 2018 2:24 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
It looks like your sway bar is missing and steering rack boots torn too.
For parts, assuming you are in Europe try Brickwerks in the UK.
Also you might want to update the thread title to refer to front suspension rather than brake calipers _________________ 1962 Karmann Ghia
Posted: Sun Jul 29, 2018 12:50 pm Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
| Jake de Villiers wrote: |
Holy cow, your suspension is completely worn out!
Plain to see how much movement there is in the radius rods in that second video - the rubber bushings are completely done - or maybe the rust has eaten out the centre of the mount...
I would think that if those bushings are that worn, then all the others are, too. Replace the lot: upper and lower control arm bushings, upper and lower ball joints and the radius rod bushings. Check the sterring rod and rod ends for play, too.
When its all done get a good alignment and go forth safely!  |
where can I buy a complete kit with all the bushings. to replace? Thank you for your time. |
Posted: Sun Jul 29, 2018 10:00 am Post subject: Re: Volkswagen T25 (1980) - problem with the brake caliper pistons? |
When its all done get a good alignment and go forth safely!  _________________ '84 Vanagon GL 1.9 WBX
